Question about Sony DAV-IS10 System
The "display" on the remote will not come up on the TV. It was working before, but not now. This needed to adjust ans set up this system.
    President:
  • 948 Answers
Make sure the TV is set to the same input you have the DAV-IS10 hooked up to.
Posted on Dec 31, 2008
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
Tip
Service menu codes panasonic
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save.
PA25UP / PD25UP / PX25UP :
* Using the remote control:
* Press the {MENU} button.
* Set "Antenna A" to "Cable".
* Select "Timer" menu and set sleep timer to 30 min.
* Press {OK} twice to exit menus.
* Tune to channel 124.
* Press and hold {VOL -} button ON THE PLASMA TV.
"CHK" appears in on top-left corner followed by 5 letter/numbers
(which are the cumulative hours in hex numbers)
* While the "CHK" is displayed, press the {OK} and {VOL+} buttons
ON THE TV simultaneously to toggle between Modes:
?ƒ?¢?¢?€??¬?¢?'¬? Red "CHK" for Serviceman ?ƒ?¢?¢?€??¬?¢?'¬? Yellow "CHK" for Aging ?ƒ?¢?¢?€??¬?¢?'¬?
* Press the {POWER} button on the remote to select one of the six
Serviceman Adjustments Modes.
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
* Press {CH+} {CH -} on the remote to select the settings
on each of Service Adjustment Modes.
Write down the original values before modifying anything.
It's easy to erroneously adjust the wrong item.
* Press {VOL+} {VOL -} on the remote to change values.
* Press the {POWER} button on the TV to exit the service menu.
LCDs / CRTs / RPTVs :
* Hold down the {VOL -} button ON THE TV.
Model PT45LC12:
1. Press and hold Vol Dn on center panel and press recall button on remote until Work Mode is displayed on screen.
2. Press and hold Vol Dn on TV and Swap button button on remote until Factory Adjust is displayed on the screen
3. Use Channel Dn button to select Digital and press the Action button.
PROJECTORS :
* Go to "Options" menu.
* Highlight "OSD".
* Then press and hold the {ENTER} button,
until the Service Menu is displayed.
* Press the {MENU} button to exit.
on Apr 29, 2015 | Panasonic Televison & Video
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
Trying to connect dell desktop to my Samsung DLP HL-R5064W tv through vga cable to watch movies. Toggle source button on remote to pc, but receive an out of range message. please help
"Out of range" message indicates that the output from your computer to display it from your Samsung HLR5064W DLP TV is too large. You need to adjust the screen resolution settings for you TV. I have attached images of display settings dialog boxes from different versions of Windows.
You may open the display settings of your computer by clicking on START > CONTROL PANEL > DISPLAY. While your TV is connected, click on IDENTIFY button. You will notice that numbers 1 and 2 will appear briefly on your screens consecutively. As the dialog box shows 2 monitors with numbers 1 and 2, click on the monitor with "2" on it. Then, adjust resolution to 1280 x 720 as this is the highest resolution your TV can handle. You may adjust the TV (monitor #2) to be IDENTICAL or to EXTEND the display of your computer. You can also assign it as the main monitor but not recommended. Click OK then try to toggle your computer's display. You should be able to see a display from your TV this time.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 22, 2011 | Samsung HLR5064W DLP Projection TV
I have the bd230 5.1 system hooked up the speakers, attached the power cord and hdmi cable from receiver to the tv what else do I need to get sound from my tv I have a hd cable.box do I need to run a cable...
The home theater box performs the production of the sound generation. Also, the theater box, distributes the sound to any display devices like TVs, Music MIxers, DVDR, VCRs, ext. The theater box also has connection ports that are recognisable as receptacle area from speakers, woofers, and twitters that combined to form the home theater of devices acquired. First, start by connecting the component parts of the theater system to the box. For example, speakers to an area on the box, twitters, woofers. At which point, the box would require a power cable to an electrican circuit to display functionality mode. The next step is deciding on which display reciver would be providing sound to the theater setup of blasters. For example, choosing to acquire sound from a TV set is achieved by connection cables that derived sound out of the TV to the theater box. E.G. The TV audio output area provides the connectivity of any external audio blasters like with the theater setup. Using the appropiate audio input output connection cables to acquire sound transfer matters. The device may not have been provided with a TV audio input out cable of connections. Acquire from retail input output cables from TV to theater boxes. Remember that, the theater box may have come with a remote control that require separe operations than the TV. The theater system theraafter would require power on buttons if any separate remote controls were acquired as well. Also, the television set would require alteration settings with the remote control. Adjusting the TV sound settings to acquire or direct internal sound to an external setup infrusture is possible explanation also achievable with TV REMOte controller soon after every wireing cables have been established alos powered on to source of current. GOOdluck
Jan 11, 2011 | Panasonic Home Theater System System
Can't adjust color, brightness, etc. w/universal remote
Use the MENU on the front panel display of the
TV
Jan 06, 2010 | Televison & Video
Hitachi TV screen adjustment
in the menu , the display or video settings should have different video display settings such as 16:9 , 1:1 , 14:9 ect... these will change the video display to different sizes
Oct 09, 2008 | Hitachi 50UX57B 50" Rear Projection...
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Cant locate or adjust the the TV color
All the controls should be accesed thru the on screen menu,your remote should have a menu or display button and if you press it on the screen of the tv you should see a list of different options ,I am not familiar with the kind of menu that your set has but I know the color adjustment should be in the same screen that allows you to change the brightness,shapness,tint,color and contrast,the more you use the menu and become familiar with it the easiest it will be to use.Let us know if you need more information.
Nov 06, 2006 | Sony KV-32S26 32" TV
Sony DAV-IS10 System Logo
55 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
