Question about Samsung Digimax D53 Digital Camera
Camera powers on then off, even when I put new batteries in.
Should the camera have came with a charger?
  • malibu4220 Jan 05, 2009
    when i turn the power button on its beeps and says low battert, even when i put new batteries in it. i had the camers for about two years now, and i finally decide to use it.
  • 33 Answers
Every new camera comes with a charger
Posted on Dec 31, 2008
My camera not comming on
There are (2) common (non-terminal) issues that cause this problem.
1) the contacts inside the camera have become oxidized...., using the eraser on the end of a pencil..., rub (clean) the contacts inside the cameras battery compartment.
2) Modern Li-Ion batteries often last only (3) years...,(if you have good ones)...., so what happens is that as the batteries reach the end of their life span they quite often will work one day and not the next (but show that they are fully charged). Thus if you only have the (1) battery, you will not know if it is the battery, the charger or the camera. Go to your local camera store (with your camera & battery) and see if they are willing to put a new battery in your camera..., if it powers up it's your battery or charger. ask if they will then try to charge your old battery on their charger for 1/2 an hour..., this is enough of a charge to find out if your camera will turn on using the old battery.
Now you must ask yourself, if I need to purchase a new battery of charger..., is it worth it.
Sep 24, 2014 | Nikon Gorilla Pod Camera Tripod For...
Why is my camera, coolpix l25 advising "battery exhausted" with brand new batteries, never had this message before?
First, I would check your batteries. Even new ones can be bad; you don't know how long they sat on the shelf. If you have a voltmeter, you can measure the output. If you do not, start by removing the batteries and making sure that the battery contacts in the camera and on the batteries are clean. If they are dirty. A new pencil eraser can be rubbed against the contacts to remove any oils or residue. Next, I would make sure your batteries are charged. A quick way is to check is to take them out and put them in another device that takes two AA batteries and see if it works. If the batteries are bad, put two new alkaline (non-rechargeable) batteries in your camera to see if it powers up. If it does and you wish to use those batteries, be sure to go into your menu and set the camera to use alkaline batteries because there voltage output is slightly different from rechargeable batteries . Remember that you cannot recharge those batteries and trying to do so can damage your charger and cause the batteries to explode. If the camera will not power up with new batteries, the camera will need to be sent in to Nikon USA for repair (see the Nikon website for information). If the camera powers up with the substitute batteries, either your rechargeable batteries have gone bad or you camera's battery charger is defective. For problems with the internal charger, it is probably more cost effective to buy an external battery charger then to send the camera in for repair unless your camera is still under warranty. External battery chargers are available for under $20. There is one other possible cause of battery failure. If the camera's internal circuitry has an electrical problem, especially a short circuit, the camera will draw excessive current from the batteries and run them down. If that is the case, you would obviously need to send your camera in for repair.
Jun 15, 2014 | Nikon Coolpix L26 Compact
Trying to buy a new charger for my camera Eurocyber
Just google for universal camera battery charger. I do use one, because I do have Nikon, Canon, Kodak and even an Epson digital camera. My charger from GP does them all. The only thing I have to do is place the contact points on a correct place. There are universal chargers you don't have to do anything, but put the battery in.
Nov 26, 2013 | Cameras
When I connect the battery charger to the camcorder it doesnt even even show that I have the battery charger hooked up nor does it charge the camera. Could that be a problem with the camera or the charger?
I got hold of Canon support. I had the same problem. Got a new battery, fully charged and would not run the unit. Canon told me to do a system reset. pull out main battery and aux battery (bottom of unit) and to power switch to aux for 90 seconds. the put batteries back and it should work. Hope this helps.
Nov 05, 2010 | Canon ES50 8mm Camcorder
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Feb 19, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
The camera doesn't open and it doesn't charge. It is dead.
I wonder if you attached the right voltage of charger.
Thats what I did. I put on a 9v dc charger
Now my v570 is dead......but ironically it will still charge a battery.
Now an expensive battery charger!
Sep 13, 2009 | Kodak EasyShare V570 Digital Camera
No power at battery and camera can not start up,battery does not charge up in charger
yea ive got the same problem
mine powers up on dc but have brought 2 new batteries and it does not power up took into local shaop they charged the bateeries still wont power up on battery
Nov 27, 2007 | Cameras
Camera won't turn on.
Mine had the same problem.  I consulted http://camerarepair.blogspot.com/ and it said to use rechargeable batteries only.  The entry claimed that alkaline batteries, even if they're brand new, don't have sufficient power for more than a few pictures and may not even be powerful enough to turn the camera on.  I was dubious, but I tried putting in a pair of fully charged rechargeables and, by Gum, the camera was suddenly working again.  So before junking the camera, try investing 20 bucks in a battery charger and a pair of AA rechargeables and see if that fixes it.
Oct 28, 2007 | Fuji FinePix A350 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
SOLUTION: Fot the past two years, fully charged NiMH and new alkaline (generic and fresh Name Brand batteries) in my CX7530 always gave a red light and immediate power off -- symptoms of low batteries. Today I tried it again with the same problem. This time, I folded up a small piece of stiff paper to depress the small Lithium battery module detect switch in the battery compartment, and put my NiMH batteries back in -- it WORKED for the first time in two years! After removing the paper and reinserting the batteries, it still works. I suspect this somehow recalibrates the low battery detect circuit. I hope it helps you as well.
Oct 18, 2007 | Kodak EasyShare CX7530 Digital Camera
Rechargeable Battery won't charge
I think this is a general Fuji design fault in the camera circuitry. I have an older F455 which has exactly the same problem and I did the same - bought new batteries only to discover that didn't help. The only solution is to spend even more money for a stand alone battery charger.
Sep 07, 2006 | Fuji FinePix A340 Digital Camera
Samsung Digimax D53 Digital Camera Logo
89 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
