Back to:
Tags:
Likom Futura LD7  17 in.CRT Conventional Monitor
Futura HD17A Computer Screen (by 3 users)
posted by boyoboy on May 05, 2007
I have two of these screens. One failed by showing a blank screen only and no graphic display. The second is now showing a shimmering screen which makes reading the display, particularly characters, difficult.
Is this a problem of a graphics card or, as I strongly expect, a screen problem. Is there a repair available or should I ditch them?
Thanks,
boyoboy.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by paulsnauith0, posted on Sep 17, 2008
hi,
i have a futura hd17a monitior .
it was working fine from new (18months)
then without warning,after switching it on,
the screen lit up,white,then after a couple of seconds the monitor goes into standby mode.
is it a driver/software problem...
or as someone suggested,the "inverter card"?
as electronics is a black art to me,i have know idea what an inverter card is ,
help please,as i cant afford to replace it at the moment.
thanks...paul
Comment by Thunderwind, posted on May 05, 2008
some of the parts of the screen is going crazy like they are changing colors. how can i fix it??
Best Solution
posted on Jul 31, 2007
Helpful (85)
Silverdragon
Rank:Wiz Wiz
Rating: 82%, 773 votes
Hi,to me it would seem real strange that TWO monitors would fault simultaniously. I would be more inclined to believe that it is the Video card itself... The ONLY way to find out is try a replacement and see... try the monitor(s) on another PC see if they work.... if they do then it's ya card 4 sure.. if it's still the same well then it IS ya Monitors good luck.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Futura HD17A Computer Screen:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Monitors
I am trying follow the steps below, I can't turn the...
Monitors
I took my car in for an oil change about five weeks ago...
Monitors
hello sir I have purchased a samsung monitor last year.but...
Likom Futura LD7 (White) 17 in.CRT...
The monitor display shrink at the center, about 2" x...
mon ecran change de couleur et affiche des valeurs...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
