Question about Seagate Barracuda ATA IV (ST340016A) 40 GB Hard Drive
Hard disk failure
While attempting to load winXP in my old hard disk,i got a error message as follows: "stop:c0000221 unknown hard error \system root\system 32\ntdll.dll" after that how many times i tried i am unable to format my hard disk using winXP bootable disk.i also used the disk manager of my hardisk it formated the hard disk with low level formatting.then i tried installing win98 but it hanged while checkin the disk.what can i do to solve this problem.
  • saroj panda May 11, 2007
    thank you.I have tried this solution but while loading windows 98 it is testing the reliability of all the drives and it is not working.I think you might have any other solution for this.
    Brigadier General:
  • 6,966 Answers
Hi, assuming the hdd won't finish a format, it is possible that some sectors are damaged. If you still want to try and use the hdd even with these defects, you can try and partition the hdd. Guesstimate at what point the hdd stops responding and really guess where the defects end. With this info, partition the hdd into 3 with the middle containing the defective sectors. Format only the first and third partitions. For simplicity, Win98 might be easier to work with rather than XP. Hope this be of some help. Do post again and let us know how things turn up.
Posted on May 08, 2007
  • Louie  Role
    Louie Role May 12, 2007
    Hi Cooltuna,
    Win98 will not check the 2nd partition (where the defects are) since it will not even recognize it (and therefore will not know if defective or not) . Of course you will not format it. The 1st & 3rd yes.
    If still win98 find defects, then the size of the second partition is still small and did not cover all the defective sectors. Go back again to FDISk or partition Magic and do the pertitioning all over again but with bigger 2nd partition.
    Pls post again. Cheers.
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
When i start my computer i get this message: stop: c0000221 UNKNOWN HARD ERROR /SYSTEMROOT/SYSTEM32/NTDLL.DLL what can i do?
I have a wipro laptop. i install windows Xp .But my system could show the operating system error . Then I am reinstalled Windows Xp. But the system will turnoff.
Dec 16, 2009 | Acer Aspire 5050-3242 Notebook
Stop:c0000221 unknown hard errorsystemRootSystem32 tdll.dll I get this error message when installing a brand new hard drive onto a HP laptop.
  1. UNPLUG THE POWER TO THE COMPUTER
  2. OPEN THE CASE
  3. UNPLUG YOUR HARD DRIVE RIBBON AND POWER CABLES AND PLUG THEM BACK IN.
  4. CLOSE EVERYTHING UP AND PLUG IT BACK IN
  5. POWER IT UP
Dec 12, 2009 | HP Pavilion zd8000 Notebook
Help
Greetings,
When you upgrade your computer to Windows XP, you may receive an error message that is similar to one of the following: C0000221 (Bad Image Checksum)
-or- STOP: C0000221 - Bad Image Checksum in ModuleName
-or- STOP: C0000221 - Bad Image Checksum. User32.dll is possibly corrupt. The header check sum does not match the computed check sum.
Please go through the below mentioned link:
http://support.microsoft.com/kb/326687
Sep 20, 2009 | Microsoft Windows XP Professional for PC
Stop:c0000221 unknown hard error\systemRoot\System32\ntdll.dll I get this error message when installing a brand new hard drive onto a Dell d610 laptop. This message appears when setup is starting windows
Hello cluikart,
Here are a couple of links that might give you an idea about the windows stop error. I hope the information on these sites can help you resolve the problem:
1). Annoyances.org: http://www.annoyances.org/exec/forum/winxp/t1030972927
2). Microsoft Support: http://support.microsoft.com/default.aspx?scid=kb;en-us;Q314474
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw562
Jul 27, 2009 | HP Pavilion zd8000 Notebook
Blue screen on my laptop
Hi vkdelaossa
That error occurs if you have installed an inappropriate driver or the .dll named in the error has become corrupt.
To fix it you would need to a Repair Install of the Operating System.
If you are not sure how to do this then please reply with following details
Do you have either a Operating System installation disk or a Recovery Disk from the manufacturer of the laptop ?(you might have been prompted to create this the first time you used the laptop)
What make and model is your laptop?
May 15, 2009 | HP Computers & Internet
C0000221 Unknown Hard Error\System32\ntdll.dll
From MS's KB:
http://support.microsoft.com/kb/314474
Feb 06, 2009 | Microsoft Office Professional 2007 Full...
Unknown Hard Error
It's probably a corrupted file on the hard drive due a variety of reasons. A simple defrag might fix it but it's unlikely, so it is probably preferable to a Repair function from your XP install CD. These kinds of errors with XP were not uncommon. After the Repair assuming it works and I'm fairly certain that it will, defrag your hard drive and then start getting the new updates for your system.
Illustrated procedures located here
Aug 26, 2008 | ASUS P4VP-MX Motherboard
Error
Hi, This is a known error and according to Microsoft could be caused by any of the following: ?Mismatched system files have been installed. ?A Service Pack installation has failed. ?A backup program that is used to restore a hard disk did not correctly restore files that may have been in use. ?An incompatible third-party program has been installed. This is better explained at http://support.microsoft.com/default.aspx?scid=kb;en-us;156669&Product=winxp Hardware side, replacing either the CD or the HD drive (or sometimes, the cable) in some instances would rectify the error. Hope this be of some help. Good luck and kind regards.
Oct 08, 2007 | PC Chips M981G Motherboard
Seagate Barracuda ATA IV (ST340016A) 40 GB Hard Drive Logo
280 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
