Question about HP LaserJet 5500dtn Color Printer
Hp 5500 dtn won't initilize
Shows ********************
on screen
    Novelist:
  • 125 Answers
1. Make sure the rear fan is running, indicating the system is operational.
2. Verify that the firmware DIMM and the formattter are seated and operating properlty,
3. Remove any Jetdirect or other EIO cards, Then try to reinit the printer again (Turn the printer back on).
I have found that if the Jetdirect card goes bad that it will halt the init proccess on the printer.
you can find out if the Jetdirect card is working just by typing in the IP address for the embedded web server
Posted on Jan 08, 2009
My printer HP LASER JET 5200 DTN shows "Ready" on the display but it doesn't print, how can I fix this?
First thing you need to do is establish whether the print engine itself is at fault, or not.
From the relevant printer front panel menu, invoke printing of one or more of the available reports (configuration, font list, etc.); do these print?
If the reports print OK, try to send some plain text to the device.
On a Windows system, you could do this by using the DOS copy command in conjunction with an appropruate net use command to redirect LPT1: to the (USB) port associated with the relevant Windows printer instance.
Jun 02, 2015 | HP Office Equipment & Supplies
Net work card config spooler
can you set copies to 5 on control panel
Oct 30, 2013 | HP Color LaserJet 5500 Printer
Hp laserjet 4300 dtn tray one pickup
Yes,
Adding the duplex attachment makes the TN a DTN nothing different in the firmware of the printer.
Feb 05, 2013 | HP LASERJET 4300DTN Q2434A LASER PRINTER...
HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Jan 05, 2010 | HP LaserJet 4350dtn Printer
Error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
May 21, 2009 | HP Office Equipment & Supplies
HP inkjet 1100 dtn network problem
i want start bussines of computor hware n sware i like to import directly
but dont have enogh fund i
Apr 29, 2009 | HP Business Inkjet 1100dtn Printer
How do i double side print with an hp 4200 dtn
HP manual for that printer is located at http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Mar 13, 2009 | HP LaserJet 4200dtn Printer
Adding IP addresses to a HP 5550 DTN printer
ok then install that printer as a network printer to one pc share ti and ad to as much pc you need after that without ip adress
Dec 10, 2008 | HP 5500 Color Laser Printer With Internal...
Driver installation problem for HP 5400 DTN
Sorry
This printer is not supported by Windows98
So HP is also not provideding Windows98 drivers
Just try to work out with Drivers for Win2000
Jun 02, 2008 | Office Equipment & Supplies
HP LaserJet 5500dtn Color Printer Logo
123 people viewed this question
Ben Johnson
