Question about GE Refrigerators
LIGHT comes on, but nothing else running.
Power come on and off several times sunday. Not home monday night, when I got home tuesday 10pm, it was leaking red juice, investigated and turned off and back on and it started running, when I got up, I checked and it appears to have run for quite some time but not running at all now. I have ice again, lights.
We have appliance repair book, and a cheap digital multimeter. Not sure meter is working. It seems the compressor is ok. But some of the other parts it says to test don't look like the book I have.
plugged back in and still nothing, just lights on.
  • 135 Answers
Check the starting unit on the compressor for power. If it has power, it is bad.
Posted on Dec 31, 2008
How did you took money for my accont on paypal I order nothing fom you
Contact PayPal, Customer service 1 (888) 221-1161 between 8AM-10PM CT, Monday through Friday and 8AM-8PM CT, Saturday and Sunday. "At PayPal, we have over 800 customer service representatives standing by."
Mar 07, 2015 | PayPal Computers & Internet
How Do I program the hpm digital time switch hl 03705 Eco Rex d11
How to Program HL 03705 EcoRex D11 Timer
The "switch" is a small rod which can be moved 5 ways - left, right, up, down and IN.
Before programming check that time and date are correct.
Time - push switch IN, then down once until TIME flashes on display. Push switch IN, then up or down continually to select hour, then switch IN, then up or down continually to select minute. Push switch IN to save.
Date - push switch IN, then down twice until DATE flashes on display. Push switch IN, then up or down continually to select year, then push switch IN, then up or down continually to select month, push switch IN, then up or down continually to select day. Push switch IN to save.
Programming - for the sake of this exercise the timer will be set to come ON at 7am and OFF at 10pm, 7 days of the week.
Note the numbers 1234567 printed just above the display window. These represent the days of the week, starting with Monday.
1. Push switch IN, then down four times until PROG flashes on display. Push switch IN. The display shows a vertical line with numbers, at the bottom of which is a digital time which should show 0:00. This is midnight, Sunday to Monday.
2. Push switch up once, this advances the time 1 hour. Continue to push switch up, one hour at a time until the digital display shows 7:00. This is 7am Monday and will be the first ON time. (Push switch to the left to change minutes, each push advances time by 1 minute).
3. Now push switch to the right and HOLD there. BE PATIENT! It takes several seconds before the time changes, firstly a minute at a time, then in 15 minute blocks. Still holding the switch to the right watch the digital time display advance (don't look at the vertical line which has another thick line develop beside it as the time changes!) until it reaches 22:00, then release switch. This is the OFF time, 10pm Monday.
4. Push switch up once, this advances the time 1 hour. Continue to push switch up, one hour at a time until the digital display shows 7:00. This is 7am Tuesday and will be the next ON time. (Push switch to the left to change minutes, each push advances time by 1 minute). Note that there is a small dot under the number 2 at the top of the display to indicate it is Tuesday.
5. Now push switch to the right and HOLD there. Still holding the switch to the right watch the digital time display advance until it reaches 22:00, then release switch. This is the next OFF time, 10pm Tuesday.
6. Continue the steps #2 and #3 through Wednesday to Sunday. You will know when you are back to Monday by looking at the dot at the top of the screen returning to be under the number 1, OR when you return to 7am Monday there will be a thickening of the vertical line starting at 7:00.
7. PUSH THE SWITCH IN TO SAVE THE PROGRAM.
Testing - To check the program settings - push switch IN, then down five times until TEST flashes on display. Push switch IN.
Each upward push of the switch moves the display through each subsequent ON and OFF change. Check the day for each ON and OFF by viewing the dot under the numbers 1234567. After the last ON/OFF change the display shows PROG END.
Operating the Program
Push switch IN, then down six times until AUTO flashes on display. Push switch IN. The device now operates on the times that were programmed. The display returns to the "home" view, showing the current time, also vertical strips lined up under the numbers 1234567, representing the times of operation each day.
Outside the display window, at the bottom of it, the words OFF and ON are printed to the left and right respectively. A cursor points to one of these to show the current status of the device.
To bypass the program - push switch IN, then down past AUTO until ON or the next one, OFF, flashes on display. Push switch IN - at ON to have device permanently switched on or at OFF for device permanently switched off.
Feb 04, 2015 | Hardware & Accessories
What are the seven days of the week? They are Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, and Sunday. But what do you call the other 358 days of the year?
They're also Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, or Sunday. These are the names of the seven days of the week. A year is fifty-two weeks and a day (two on leap years).
May 13, 2014 | Office Equipment & Supplies
Intermatic EH10: I can't figure out how to set a schedule of Sun - Thurs, 8am on, 10pm off and Fri & Sat, 8am on, 11pm off. I tried every day of the week 8am on, 10pm off and Fri & Sat 8am on, 11pm...
http://waterheatertimer.org/pdf/eh10-manual.pdf
The EH10 is 120V digital timer.
The timer offers the following days:
-All 7 days
-Monday thru Friday
-Saturday and Sunday
-Each individual day
-Blankday (day skipper)
If I understand your schedule:
You want
Program1 ON at 8am Sunday
Program1 OFF at 10pm Sunday
Program2 ON at 8am Monday thru Friday (with blankday on Friday)
program2 OFF at 10pm Monday thru Friday (with blankday on Friday)
Program3 ON at 8am Friday
Program3 OFF at 11pm Friday
Program4 ON at 8am Saturday
Program4 OFF at 11pm Saturday
I filled in the chart for you.
I left off the display.
I do not have this timer and don't know 100% how the display looks without buying the timer.
If you need more help on a specific step in the manual, add a comment and I will answer.
Nov 07, 2010 | Intermatic 7 Day Electronic Timer Eh10...
My 1999 yukon wont start i changed master air flow
Fuel pumps are real common to go out on those vehicles
Mar 15, 2010 | 1999 GMC Yukon
Wont Crnk
did ya get it goin???? havent heard from you???????
Oct 26, 2008 | 1995 Jeep Cherokee
1992 jeep engine problem
hello did you get your question answered?
how was the support
thanks
paul
Oct 24, 2008 | 1995 Jeep Cherokee
Wont Crank
It's probably one of these:
1.NSS- (Neutral Safety Switch)
2.CPS- (Crankshaft Position Sensor)
**Look here-
CPS 1/2 way down..
http://www.lunghd.com/Tech_Articles/Engine/Basic_Sensors_Diagnostics.htm
**And here-
NSS.. .
http://www.cherokee-jeep.com/1-2swremov.htm
Wont Crank
im thinking its the starter..i would take it out and brin it into like an autozone they test them for free..
Oct 24, 2008 | 1995 Jeep Grand Cherokee
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
