Question about Maytag Neptune FAV6800AW Top Load Washer
Out of balance top load washer
Maytag Dependable Care top load washer. Went out of balance to the point the drum was banging on the inside of the housing and it would shut itself off. Loads were balanced, machine is leveled well. I took off the front and inspected the springs, and they look great. What should I do?
  • 335 Answers
This was my fix, my machine that would error out with DC/UC codes.
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley, just follow the service manual removal steps to remove the clutch pulley. Pull the plastic cover off the clutch pulley and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 4 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, good luck!
I found a link on this site
http://www.servicematters.com/maytag_library/docs/16022808.pdf
Posted on Jan 02, 2009
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
I have a Maytag Performa top loader that won't stay in balance
make sure you locking the legs,
put it in spot tilt it forward so the rear legs are off the ground about 3'' the drop it,, this should lock your back legs and take care that
Oct 06, 2009 | Maytag Performa PAV3200
Washer quit mid cycle
open lid pull tub to you till you hear a click(when you have an off balance load the tub will trip the switch)
Aug 22, 2009 | Maytag Dependable Care LAT9706
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Jul 05, 2009 | Maytag Performa PAV2200
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Washer won't switch from rinse to spin
You have a bad lid switch. Before I retired Maytag had a lid switch kit that improved the switch that was originally in it. The problem would usually present itself if a person accidentally dropped the lid with a bang which would put the lid switch out of adjustment.
Jan 08, 2007 | Zanussi ZJD1219 Front Load Washer / Dryer
Maytag Neptune FAV6800AW Top Load Washer Logo
435 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
