Question about Jaeger-lecoultre Master Compressor Memovox 1708170 Wrist Watch
How to set day,date,year on a Jaeger Coultre Master Grand reveil
I just got a Jaeger Coultre Master Grand reveil watch, without box or papers and don't know how to set the day,date, year. It is aperpetual calendar
thanks
Aqua master professional chronograph
the crown on the side pull out . should have 2 positions . first is for day//up and turn down for date. pull out all the way and set time .. set the day for the day before and go past the 12 first time you know you in am set accordingly. see the am /pm is important. date changes past 12 pm
Jan 31, 2012 | Aqua Master 32-6-66P Wrist Watch
I can't set the date on my watch - right now I have to scroll through the time setting mechanism hour by hour and day by day?
The date changes around midnight and you can usually advance the date by going past midnight until the date changes and then turning the watch backward to a time shortly before midnight and then winding it forward again.
How far back you need to go you will have to find by experiment but it should not be very far.
Jun 09, 2011 | Jaeger-lecoultre Master Compressor Memovox...
I have jlc movement 450 with dial but case is missing
cousinsuk.com choose branded watch parts, select the brand and search. They are in England but I use them all the time, you have to go through there little signup procedure but whatever it takes, right?
Feb 12, 2011 | Jaeger-lecoultre JaegerLeCoultre Master...
The moving mechanism inside gets stuck and i have to violently sheck the watch to get it lose and start working
mcdevito75 here, Sounds like you need the watch serviced, specially if not so in 2 years. Check the repair service directory here at Fix Ya, bottom of the page click on repair service directory then watches.
Jun 25, 2010 | Jaeger-lecoultre Master Compressor Memovox...
Problems with setting the date on this watch
mcdevito75 here, It does seem to be a hard way to set the date. I would imagine to you have stem and not buttons, Try this slip your fingernail just under the stem (winder) and lift the stem to it"s first position, now turn the stem either toward or away from you to change the date easily.
Jun 21, 2010 | Jaeger-lecoultre Master Compressor Memovox...
Bucherer Day/Date Setting Problem
You have to change day by the means of moving hands clockwise. Move as long as the desired day appears in window, then adjust the date and set time. Rate me, plz.
Mar 31, 2010 | Watches
Winder has broken off jaeger-lecoultre watch
Yes, but for an authentic Jaeger-lecoultre watch it will be very expensive.
Dec 30, 2008 | Jaeger-lecoultre Reverso Classique 2798120...
My memovox is running too fast got it now for about a month
Your question was cut off please explain your problem further Don
Jul 01, 2007 | Jaeger-lecoultre Master Compressor Memovox...
Jaeger-lecoultre Master Compressor Memovox 1708170 Wrist Watch Logo
147 people viewed this question
Top Jaeger-lecoultre Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Jaeger-lecoultre Watch Expert? Answer questions, earn points and help others
