Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Slow internet connection speed
I have a befsr41 ver 3 that reduces my connecion speed from 25 directly connected to 5 when using the router. I also have a blinking full/col led. I ran easy link advisor and it said my network was ok but did show a ! in a yellow delta athe the comcast connection. Any help would be appreciated.
  • Mitja vanderapffel Jan 15, 2009
    I have problem to download and my system tells me taht connectin is not good. I have 4 mb down and1 Mb up connection.
    My coonection is bad, slow, weven i have 4 Mb down and 1 mb up connection calble.
    what to do to resolve problem with router Linksys BESFSR41 router ?
5 Suggested Answers
debbily
  • 101 Answers
SOURCE: 3 PC's networked to BEFSX41 very slow accessing internet
sounds like your internet access is the slow down, not the router. You don't say if you have DSL or CABLE or what.  I'd check there. Make sure you are getting a strong signal.  Hook up one system directly, without the router and check the speed.
Posted on Oct 14, 2007
shindou
  • 70 Answers
SOURCE: Linksys router limits speed to 5 meg.
Try to access the router's setup page and change the MTU settings. The default address for the Befsr41 is 192.168.1.1. Here are instructions:
1) Use a computer wired to the router.
2) Launch a browser and type in 192.168.1.1, leave the username blank and the password is admin or the password you have set when you first configured the router.
3) Click on the Advanced tab then click on the Filters tab. On the bottom part you have MTU.
4) Enable that option and set MTU to 1500, 1400, 1300 (for cable ISP connection) and 1492 (for DSL connection) and check if it will work.
4) If that does not work, you can try upgrading the firmware of your router.
Posted on Apr 30, 2008
dante777
  • 623 Answers
SOURCE: Help please! TP-Link Wireless Router TL-WR641G stopped working
It looks like all your devices by themselves are working fine.
Good start.
If you took the router out of your office I assume that the settings from the office and your home are different, which causes the setup not to work properly.
First of all you should find out which hardware version of the router you have and download the manual from here, so you have the information at hand when you're not online.
Then you want to rest the router to factory settings, so you start clean. In order to do so, use the Factory Default Reset button: First, turn off the router's power. Second, press and hold the default reset button then turn on the router's power, until the SYS LED lights up (about 3 seconds). Last, release the reset button and wait for the router to reboot.
Follow the instructions in the manual form page 8 on onwards with a special view on setting up PPPoE. Have your information form your DSL provider handy (Account name and password).
The default webpage for the router interface is http://192.168.1.1
Username and password are both "admin".
Do not enable any wireless security until everything is working fine.
Make sure later to change the password to something else, so no one can "take over" your router.
If this solution did not help, please don't rate it as "Thanks for trying" or so, but leave a comment instead and I will check back and we can work form there.
Posted on Jan 27, 2009
  • 41 Answers
SOURCE: Configure Router
Make sure that the modem is connected to the internet port of the router and computers to munbered ethernet ports.open 192.168.1.1 in your internet explorer page.It will ask for username and password.Leave the username blank and in password type admin.You will get the linksys page.In the blue bar click on MAC address clone.Enable the MAC address clone service and click on clone.Now scroll down and click on save settings.Make sure that all these settings are done from the computer which is able to go online.Now power off your router and modem.Now power up modem first and then your router.Now you will be abvle to go online from all the computers.
Posted on Jun 03, 2009
bschilz
  • 2049 Answers
SOURCE: Moved router to connect directly to the Comcast
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Posted on Nov 26, 2009
Slow internet speed when connected to router
So, If you have internet connection speed problem with your wireless try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
Jan 26, 2013 | Linksys WRT54G2 Wireless Router
Slow upload speed
It is usual that the internet speed differs when connected to a modem and a router. You have many possibilities to get signal affected while connected through a router.
Anyway you can try with these basic steps to get a better connection through router,
1.) Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.com before and after performing these steps.
Sep 12, 2012 | D-Link DGL-4500 Wireless Router
I bought a Belkin 'Play' router to provide wireless internet connectivity from my CLEAR modem. I can't get the router to speedtest at half the speed as being directly connected (via ethernet cable) to the...
Use an Ethernet cable from the CLEAR modem into the WAN (or 'Internet') port on the Belkin.
Take a close look at the 8 coloured wires at each end of the Ethernet cable.
The 8 wires must be coloured in the _same_ order at both ends.
Be sure that you have a 'CAT-5' or 'CAT-5E' cable, not a 'CAT-3' cable, which is much slower, over long distances.
Use another Ethernet cable from one of the (three? four?) 'LAN' ports on the Belkin to the network-port on your computer. Again, check that you have a "straight-through" cable, not a "cross-over" cable.
Turn the CLEAR modem off.
Turn the Belkin off.
Turn your computer off.
Turn the CLEAR modem on, and wait until its lamps settle-down to a consistent pattern.
Turn the Belkin on, and wait until its lamps settle-down to a consistent pattern.
Turn your computer on, and let it boot.
You now should have Internet access.
Note that the router "dynamically" shares the Internet connection.
If there are 4 'LAN' ports, then each of the LAN ports gets as much speed as it needs;
you do not have a 25/25/25/25 split, unlike cutting-up an apple-pie to feed 4 people.
Run a "speed-test" on your computer, and you should be getting as much speed as you are paying for. Having the Belkin in the "middle" of your network should *NOT* slow-down the speed-test at all.
Apr 04, 2011 | Belkin (F5D7230-4) Router (587009)
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
Slow or no connectivity with linksys modem
- Changing the LAN IP Address of your Linksys will do to fix the issue.
Mar 16, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Apr 29, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Low outgoing internet
If you are experiencing slow speed while connected to a router, there are a number of things that can cause that problem.
If its the router causing the problem it could be a bad router, or a setting on the router.
1.) first thing i would do is a traceroute to google.com so from a command prompt type tracert google.com and see if your few hops are high. if they are when the router is connected but not high when the router is disconnected, then we know its something with the router.
log into the router's configuration.
2.) on some models you can change the MTU size.
3.) make sure your not filtering any ports that you need such as 110, 25
start with those 3 steps and let me know how that goes.
Feb 20, 2008 | Trendware TEW-452BRP Wireless Router...
Oct 14, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
Red Diag light blinking on the BEFSR41
This is caused by the firmware not loading correctly. Follow the steps below to fix this: 1. You will need to gain Internet access to download the latest firmware for your router. The firmware must be present on the computer that will do the upgrade. Temporarily bypass the router and plug directly into your Internet Service Provider?s modem to gain access, or use another location other than your own to get to the Internet and download the firmware. 2. Download the latest firmware for your router from http://www.linksys.com/download/firmware.asp. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version (select BEFSR41, do not select BEFSR41 Ver. 3 ). 3. Click the ?Get Upgrade? button. 4. After the firmware page opens, click the link that says, ?Click here to download the latest firmware...? and download the firmware file. 5. Once you download the Zip file, unzip it and extract all files. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. Before performing the upgrade, assign your computer a static IP address. For more information, please see Answer ID 534 for instructions. If using a 10/100-network adapter, change its speed to 10Mb, half duplex. For instructions on doing so: Windows 95/98/ME 1. At the Windows desktop, click on Start then choose Settings and click on Control Panel. 2. Double click the Network icon. This will bring up the ?Network Configuration? window. 3. Locate and highlight the icon with the green logo for your network adapter and click Properties. 4. This will display the network adapter's Properties. 5. Select the Advanced tab and click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Once this has been changed, click OK to return to the Network configuration screen. 8. Click OK again and Windows will ask to restart your computer. Click ?Yes? to restart. Windows 2000/XP 1. Go to Start click on Run and type in control ncpa.cpl. 2. Double click on the Local Area Connection that controls your network card. 3. Click Properties under Local Area connection status. 4. Click the Configure button. Then, click on the Advanced Tab. 5. Click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Click OK after you made the change then click Close. Reloading the firmware 1. First, hold the reset button located on the back of the router for 30 seconds. 2. Next, to test communication between the Router and the network card: Go to Start, and select Run. Type in command and press [Enter ]. This will bring upthe MS-DOS promptwindow. 3. Type ping 192.168.1.1 and press [ Enter]. 4. You should get the following results: Pinging 192.168.1.1 with 32 bytes of data: Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 5. Once you get these replies, close out of the command prompt by typing in exit and pressing [Enter ]. 6. You may now proceed to upgrade the router?s firmware with the files that were downloaded. 7. Once the upgrade is complete, the router's red Diag light should no longer be blinking. Note: Be sure to go back to your network card settings (from the steps above) and change the speed of the link back to ?Auto sense? or ?Auto? (the original default setting) to restore full speed to the adapter. If any of the steps do not work, or if you are having other difficulties, please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
121 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
