Question about Hoshizaki Refrigerators
My model #is km-500mrf and the machine has got the 3 beep syndrym and I dont know what it means except what it says on the cover plate could u help me it is a Ice machine
  • 2 more comments
  • fritz301 Dec 31, 2008
    yea he didnt tell me anything but I dont have a manual and i need assistance from someone that knows about ice makerscan u help me or not i dont need another bill for 9.dollars the thing just beeps 3 times and it saysthat 3 beeps every 3 seconds=Freeze Back up Timer >. Freeze> Specfied setting.Yellow LED marked "F timer"energizes. Check for F/S stuck closed (up), WV leaking by, TXV not feeding properly,low charge,or inefficient compressor. Dip switches 9 and 10 allow for factory adjustment of this backup timer feature. this machine is a hoshizki ice maker model # km-500 mrf
    well yes if u dont mind the 3 beeps every 3 seconds it will harvest a couple of cycles and then will beep on and just run and not makle ice
    well I didnt get any worthy answer for my problem and i wish if this is all I got u take me off and reimburse my money back thank u or just help me with the problem or say something any way like hello or t5hat u are working on it or something thanks bill,
    well I told u every thing about it and still no answer
    Sergeant:
    Champion:
  • 304 Answers
May i know if the unit was still ruinning, or any other indications to the problem.
kindly add more info on here.
tnx
Posted on Dec 31, 2008
  • 142 Answers
Im not too familiar with refrigerators but there should be an answer in the troubleshooting manual or from the maunfacturer.
The KM-500MAE has 3 beeps in 3 seconds after 2 consecutive cycles. What should I check?
Hoshizaki has service info on line in pdf format on servicing and trubleshooting. The machine itself has info on what three beeps message is. Sorry, no pinpoint fix
Aug 25, 2015 | Freezers
Emacine t2042 beeps once-beeps 3-beeps3-beeps once butr does not boot. What the heck does the beeping mean?
Open the cpu cabinet cover . Then reconnect RAM memory to motherboard clean dust from all parts. Reconnect processor and it's fan reconnect pci if any. Reconnect both connection to harddrive. Make sure motherboard is not ground with cabinet cover. then check. Let me know if you need further assistance. Thanks for using FixYa.
Sep 25, 2011 | E-Machines T2042 PC Desktop
I have a Hoshizaki model Km-250baf it beeps three times.
3 beeps means it has been in the freeze cycle too long. A stuck float switch can cause this as well as a leaking water valve. Look for that first. Let me know if you need more info.
Feb 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
KM-500-MAE Problem huge cubes,alarm code 3-beeps
excessive freeze cycle=60 minutes. In almost every case, it's the water valve (sometimes called the fill valve) is leaking water continually into the sump. Turn machine off and see if you can still hear water running into the unit. If so, it the valve leaking. Just replace it.
http://www.hoshizakiamerica.com/manuals/KM-500M_E_serv.pdf
Go to this site and download you copy of the service manual. It has lots of good stuff.. Let me know if I can be of any further help.
Sep 30, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Beeps 3 times when turned on
3 beeps means the machine has ran two 1 hour cycles back to back to make ice an average timeframe for ice making is 25-30 min. Could be several issues, float switch dirty, water valve leaking by, dirty spray tubes, dirty evap., then go to refrigeration Expansion valve, compressor, charge, Hot gas valve leaking by,,,,,
Jun 23, 2009 | Hoshizaki Freezer Commercial Ice Machines...
My ice machine only harvest 2 time and start to 3 beep eveaperater very clean no scales inside because i descale every 2 weeks can u help me
In most cases, there is a chart on the inside of the front cover. It may also be located on the side of the box where the control circuit board is located. It will tell you what the 3 beeps mean. Hoshi has a great tech support. It's worth the wait.
Feb 02, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine with constant beeping every 3 seconds
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
It wont stay on
probably bad memory, 256MB DDR (PC 2100)
Jan 21, 2007 | E-Machines T2642 PC Desktop
Open Questions:
Refrigerators Logo
Top Hoshizaki Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Hoshizaki Refrigerator Expert? Answer questions, earn points and help others
