Question about Ricoh FAX5510NF Plain Paper Laser
Richo 5510nf isn't sending the faxes to the pop server
I've checked all the network settings, everything is correct. No matter if its immediate transmission or delayed into memory, it still just puts "error" in the journal (log).
Any suggestions? I know the pop account works, the DNS/router is correct. Its all up to par.
Thanks for your help, I'm stumped for 3 days now.
  • mark160 Jan 12, 2009
    Faxing from memory works without a problem. It is only the scanning function that fails.
Pretty sure it isn't compatible if your email account is using SSL.
If you have another account you can configure without SSL, it should be fine. Gmail used to work, but even that is using SSL now.
Posted on Feb 19, 2009
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
First, disconnect the fax from the wall and any other device ( after powering down), let set about 30 sec to 1 min. and then only plug the power and phone line into device and power up. Try a hook ( like you are making a call) call to a known fax number, listen for the communication tones -- if they are there, hang up and try to send a fax to that same number. If the error continues you have a scanning problem with the device.
Posted on Jan 04, 2009
I cannot access my emails in my outlook account on my Toshiba CB50 Laptop it keeps saying theres a problem with my account why is this?
Solution: Make sure that your computer is connected to the Internet or your network. Use a Web browser to see whether you can access Internet sites. If you are on a local network, see whether you can access intranet sites. For information about checking the status of your network connections, see Mac OS Help. Solution: Verify that Outlook is online. On the Outlook menu, make sure that Work Offline is not checked. Cause: Some POP and IMAP e-mail accounts use an outgoing mail (SMTP) server that requires authentication. Solution: Turn on SMTP authentication for the POP or IMAP account. Some e-mail services, including MobileMe mail accounts, require authentication for their SMTP server. If you verify that all your account settings are correct, but you still can't send messages, try turning on SMTP authentication. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. Under Outgoing server, click More Options. On the Authentication pop-up menu, select the authentication type, and then enter your credentials as necessary. Cause: Your ISP or network has a firewall that blocks connections to your e-mail service's outgoing mail (SMTP) server. Solution: See if your ISP or network administrator can provide an alternative SMTP server to use for your POP or IMAP account. If you have the address of an alternative SMTP server, enter it in your account settings. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. In the Outgoing server box, type the server name or address. NOTE: If you use a laptop computer in multiple locations, such as at home and at work, the SMTP server that you use in one location may not work in other locations. Each Internet connection that you use may have a firewall with its own restrictions. Cause: Your credentials or account settings are incorrect. Solution: Verify that your account user name, password, and other settings are correct in Account preferences. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. Make sure that you have entered the correct e-mail address, user name, and password. If your account still does not work properly, check with your e-mail service provider for details about how to configure your account in a mail application. Your account may require that you use special settings such as Secure Sockets Layer (SSL) to connect, or that you override the default port. Cause: Your network requires a proxy server to connect with the mail server. Solution: Specify a mail proxy server in your computer's System Preferences. If you use a network to connect to the Internet, you might have to specify a mail proxy server. Ask your network administrator for the correct settings for your mail proxy server. For instructions about how to enter these settings, see Mac OS Help. Cause: Your e-mail server is unavailable. Solution: Make sure that the mail server is online. If you successfully connected to the account before, the mail server might be offline. Contact your e-mail provider or network administrator to see whether the mail server is available.
Mar 25, 2016 | Toshiba Computers & Internet
Tip
SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)Posted by...
<a href="http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/">SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)</a> <span>Posted by <a href="http://www.smtp2go.com/blog/author/admin/">mi6</a> on </span>August 19, 2009 - 4:06 am <span>Filed under <a href="http://www.smtp2go.com/blog/category/uncategorized/">Uncategorized</a></span> Some Sharp fax machines require a certain type of SMTP server in order to be able to send emails. SMTP2Go provides an SMTP server that authenticates senders based on their 'from' email address, meaning that it works with fax machines that are unable to send an SMTP username or password.<br /> Two examples of SMTP setup procedures for popular Sharp fax machines are below:<br /> Sharp UX-B800SE and UX-D1200SE Broadband Fax SMTP setup In the 'Network Settings' area, enter smtp2go.com as the SMTP server, and <b>UNCHECK</b> the box 'POP before SMTP'. Try entering either port 2525, 25, or 587 as the outgoing SMTP port. Then, make sure you are sending 'from' an email address that is registered with SMTP2Go.<br /> See a sample screenshot from the UX-B800SE fax below (click on it to enlarge):<br /> <br /> <p><a href="http://www.smtp2go.com/blog/wp-content/uploads/2009/08/sharp_fax_ux-b800se_smtp_setup.gif"><img src="sharp_fax_ux-b800se_smtp_setup_small.jpg" /></a><br /> Please note that Gmail's SMTP server doesn't work, as it not only requires a username/password, but it also requires that SSL/TLS is used.<br /> Please note: some fax machines may still have a problem sending - if this is the case, use the IP address of 207.58.142.213 instead of smtp2go.com as the SMTP server.<br /> SHARETHIS.addEntry({ title: "SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)", url: "http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/" }); <span><a><span>ShareThis</span></a></span><br />
on Feb 15, 2011 | Office Equipment & Supplies
Sandra4609g@btinternet.com
Every iPad should be capable of sending email. You first have to setup the account, in settings, then email, then add new account.
While entering a new account, you have to fill in all settings correct, so you need to know it it is a POP or SMTP server, you must fill in the complete and correct e-mailadres and server name and the correct password. if filled in and you press next, the program will check the validity of the address. Only if the address exists and the password is correct it will tag everything green. Then you can use the mail address. It must be an existing mail address. You can't create new addresses in that part.
I'm not sure if you are running the iPad on a G3 or G4 network from BT, because that firm can try to block other mail, to save bandwidth, but I don't believe that.
You should be able to setup the BT account. If you keep having trouble setting up the BT account, visit a bt store and ask them to setup your mail address
Jul 18, 2014 | Yahoo Mail
Why is my fax not working all of the sudden?
Perhaps the Fax (phone) line is dead or disconnected. Can you hear any dial tone?
If not, ring the Telco
Apr 22, 2013 | HP Officejet Pro 8600
I'm trying to figure out how to scan a document and send it to email using an IKON (Canon) imagerunner C3220 copier? Is this possible?
The following steps will allow you to send and receive E-mail: 1. Make sure you have all of your TCP/IP information set up (IP address, Subnet Mask, Gateway, DNS Server (if one), Host Name, and Domain name of your Domain) before you begin.
2. Enter into the Network Settings and Select E-mail/I-Fax.
3. If you are setting this up for SMTP (Simple Mail Transport Protocol) to send E-mail and I-Fax, enter the IP address or Fully Qualified Domain Name (FQDN) of your mail server in the SMTP Server section. For example: mail_server.organization.company.com. Then enter the email address that will be the default sender in the SMTP Address field.
4. If you use POP3 and want to receive e- imageRUNNER mail and I-Faxes, fill in the IP address or FQDN of your POP3 server and the account added for the imageRUNNER-iR. The password is optional and needs to be entered if set on the e-mail account of the imageRUNNER-iR. Set the POP interval (how often the machine will log in and check for mail).
5. Reboot the device.
* Note - AUTHENTICATION ISSUES -
-If the SMTP mail server requires authentication for sending email, enter Encryption/Authentication login information (SMTP authentication via a username and password).
- For the models that do not support SMTP authentication, the administrator will need to set up a SMTP Relay.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
Faxpress sent faxes vanish
Immediately after posting, received SPAM from this site. Was offered some type of professional "elite" help. New is: I AM AN ELITE PROFESSIONAL. This is a gimmick site that harvests information and harasses you to buy something.
Jun 06, 2009 | Castelle FaxPress 2500 Fax Server
Code 721 keep coming up and the machine keeps beeping. How do we fix it?
Error 721: Cannot connect to the Pop Server. (Incorrect POP Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the Network Administrator
Were you setting up email by chance, you need to make sure the email server settings are set correctly for your POP email provider. Otherwise you will get this message. If you don't use email, go into settings (Fax Parameters) and disable email features.
Apr 27, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Problem with fax on estudio 3511
When enabling the Offramp Gateway, this equipment works as an SMTP server to receive
Emails from the Internet. To enable the STMP transmission in this equipment, designate the hostname (or specific domain) that relates to this equipment in the DNS server, and designate the MX record to receive the Emails that are sent to the equipment’s domain in the SMTP server in your local area network. Then the SMTP server should be configured to transmit the received Emails to the equipment in the SMTP transmission. For example, if the hostname of this equipment is designated as “host1.ifax.com”, the SMTP server receives an Email whose forwarding address is “<account name>@host1.ifax.com”, and the SMTP server transmits the received Email to the equipment. Then this equipment will send the received Email as a facsimile document to the fax number that is specified in the <account name> part.
Setup Procedures:
1. Setting up the DNS server and SMTP server.
2. Setting up the TCP/IP and the HTTP Network Service to enable TopAccess
3. Setting up the SMTP Network Service.
4. Setting the Internet Fax Settings.
5. Setting up the Fax Settings
6. Registering the Relay Box with Email addresses.
Dec 19, 2008 | Toshiba E-Studio 161 Copier
Ricoh 5510nf 0500 error
cleaned toner spilled inside and replaced toner ,turned off and on and the error messege went away
Mar 11, 2008 | Computers & Internet
Richo Aficio 5000L Fax - Fax Operation not working !!!!!!!
First, determine whether the telephone line is working properly. Remove the telephone line from the machine and replace with a test handset. Try calling the fax number and see if you get fax tones on the handset. If not, there is a problem with line switching. If you do get fax tones, then the machine is at fault. Now plug the line cord into the machine, check that it is in the correct input jack, as there may be unmarked jacks open on this machine. Check the display and see that it is ready.Is the machine trying to communicate with another fax number? If so, change the service station fax number to a machine that is close by.(User Tools 2 then immediately 1998 start within 3 secs. then 13 and change the number.) Try to send or receive a fax and observe there is or not 3 sheets of data sent to the machine you just programmed as the service machine.So then, is the machine configured with 1 or 2 modems? Determine that the problem happens with both modems. If so, the modem is not suspect. Now let me stress this, that if you are not a qualified Ricoh technician, do not attempt any further checks yourself.
Next, do a complete level 3 reset. Remember that the machine may be configured with a feature upgrade card which may contain 999 additional speed dial numbers. Do not remove this card yet. However, repeat the receive checks with the memory card removed. If there is no Feature upgrade card or a fax on demand card in the left hand slot, then check the contents of system switch 16. If this is set to 1. If so, then the machine will not work unless a ic or data copy tool is present in the slot. Repeat the tests. Power off and remove the memory card and the feature upgrade card. Power on. Set System switch 16 to 0 and repeat the tests.
Theres more tests, but I don't have the space to go through them all, the manual is 300 pages.
Jan 24, 2008 | Office Equipment & Supplies
Ricoh FAX5510NF Plain Paper Laser Logo
182 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
