M & K subwoofer speaker replacement
I would like to find a replacement speaker for the V2B Volkswoofer. It is a 12" speaker, with a integral amp (250 watts)
  • maribel_rd Jan 03, 2009
    I HAVE THE HOME THEATER TR-606 AND A LOSS THE REMOTE CONTROL A NEED HELP ABOUT THAT
4 Suggested Answers
SOURCE: klipsch subwoofer
call Dr. Korvorkian! He will help.
Posted on Jan 07, 2008
  • 16 Answers
SOURCE: JVC Subwoofer problem.
You may have a break in the wire. You can find out by slowing moving your fingers down the wire until you notice sound coming from the subwoofer. You can fix it yourself by cutting about an inch away from the break both ways. Then cuttings some of the wire off, so the copperwire is exposed. then wrap the two copperwire ends together and seal it with elections tape. or Try replacing the 60 watt subwoofer wire.
Posted on Apr 16, 2008
  • 133 Answers
SOURCE: When I push my subwoofer cone its work and when i
Looks like a broken copper braid that links the speaker terminal to the cone (from there on it goes to the coil which is underneath the cone).
Check the speaker connection terminals (near the magnet), you will notice that each terminal has a copper braid wire going from that terminal to the speaker cone.
Inspect both braid wires carefully at each end (near the speaker terminal and near the speaker cone), there will either be some damage to the braid at one or more of these four locations or the braid could be actually broken at any of these spots.
The braid can actually be resoldered at the point where it's damaged or broken - this task will require good soldering skills, mainly because this kind of braid wires are difficuld to solder (they are a bit difficult to clean because of their structure and solder won't attach itself well to oxydized copper), but also because some speaker cones are made of plastic which may melt if you overheat it with a soldering iron.
Besides that, when resoldering is being done, only a very short portion of the braid should be wetted with solder because the solder point will become rigid when the solder cools down, and the braid needs to remain very flexible when the speaker operates (if it's too rigid or too short, damage to the speaker cone could occur or the braid could get broken again when the speaker will be playing at a loud volume).
Hope you can have it repaired, it can be done at home, but there are also speaker repair shops where you can get it done (i'm not sure about the prices though).
Anyway, the alternative is to replace the speaker itself.
regards
3rq8 (Triarcuate)
Posted on Sep 11, 2009
How do I hook up a sub woofer & speakers to my car stereo?
If you are replacing the existing door/deck speakers with replacements of the same size and not adding an amplifier, you will be able to use the existing wiring, making note of the positive and negative notation.
Subwoofers, on the other hand, require an amp. There are subs that have an integrated amp in the enclosure, otherwise you will need to buy a separate amp. Connecting the amp to your existing system will highly depend on what outputs your head unit (aka stereo) has. If it has pre-amp outputs, those can be run straight to sub amp. If there are not pre-amp outputs, you may have to buy a "high level" adapter that connects to the same head unit outputs as your speakers.
Jul 02, 2016 | Car Audio & Video
Why is subwoofer output weak?
Change the gain and the frequency settings
Jul 07, 2015 | Car Audio & Video
Can a 250 watt amp power a 12 inch sub
It certainly can, and it MAY provide too MUCH power to that sub. That's a lot of amp.
Jul 12, 2014 | Kenwood Car Audio & Video
Need to find parts or data sheet for ps-12 subworrer amp or amp replacement
Infinity will sell you the service manual for $20 (I think)
1-800-553-3332 ask for parts or
parts@harman.com
We also sell the complete amp ***'y part# 351648-001 but they are not cheap.
parts@harman.com
Nov 17, 2010 | Infinity PS-12 Subwoofer
Have alpine 10 r subs can insignia 500w amp hook up and how to wire subs
if the speakers are 250 watts each then yes if speakers are less you will blow them cuz of to much power if they are more then you most likely won't be able to push them
Sep 24, 2009 | Insignia 600W Bridgeable Amplifier with...
How do you hookup 2cvr 12 to a mono amp?
Hook together both positives from each speaker together and both negatives from each speaker together and hook them up as one connection to your amp.
May 18, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Bass not Very deep
250 watts rms seems a little low for a 12 inch woofer, a 500 or higher will likely fix your problem. Specific model numbers and the type of enclosure you have will allow a more specific answer.
Mar 17, 2009 | Car Audio & Video
Wiring
Run a Jumper from coil 1 + to coil 2 + and a jumper from coil 1 - to coil 2 - and then run + from coil 1 to amp and - from coil 2 to amp. This will put your load to 3 Ohm and that will give you the most power. You could get more by going to 1 ohm but I don't think the mtx amps are stable at 1 ohm.
Sep 30, 2008 | Jl Audio 12W3 Car Subwoofer
PowerAmp for Mmats 2.0 12" SubWoofer
what model speaker. i recommend matching your MMATS speaker with a MMATS amp. Match the RMS
May 19, 2008 | Mmats 12 Car Subwoofer
322 people viewed this question
 Grubhead
Grubhead
