Question about Dell OptiPlex GX240 PC Desktop
WHEN BOOTING UP A DELL OPTICPLEX GX240 fan turns on I get 3 beeps
I do not get any picture on screen, I checked the monitor on another cpu and there were no problems.
suspect a bad VGA card. My question is does it matter
if I use any type of video card or I have to install the one for this model ?
My cpu cannot send a signal to the monitor
Posted on Mar 10, 2009
    Master:
  • 413 Answers
Http://www.unitedmicro.com/tech/signal.htm#question%202%20no
Follow the above link and if it does not help just let me know and ill try to help you further
Posted on Dec 31, 2008
How to reset cooling fan alert on Dell Optiplex Gx240?
Are you using a four pin connector( connected to power supply)? if yes it will give you error. Connect the fan as shown in the image
Feb 04, 2016 | Dell OptiPlex GX240 PC Desktop
Dell OptiPlex GX240 PC Desktop cannot power up
Do you hear any beep sound when you power on the PC? Check the following componente PSU,video card (if you hear one long beep),or RAM memory if you hear 3 long beeps.
Apr 06, 2014 | Dell OptiPlex GX240 PC Desktop
I have a dell 580 inspiron thats does not turn on..before it turned on but now it just beeps and doesnt follow through with start up.......i had a blue screeen before this ....thanxx
Blue screen could be the windows files getting corrupted due to a virus, file fragmentation or a failing hard drive, overheating cpu or failing memory.
The beeping usually indicates a hardware failure, first open the computer and see it the CPU heatsink is in place properly seated and fan is connected and spinning.
Second with the PC off, remove and reinsert the memory.
These are just a few things to check , most likely the hard drive has failed and needs replacing.
pressing certain keys during bootup can sometimes isolate the issue, but only if the monitor still shows a picture
I hope this helps
Thanks
Roety
Aug 23, 2011 | Dell Inspiron 580 Desktop Computer (Intel...
Got an interesting issue. I've got a dell inspiron 531 with a dell ry206 motherboard. Bad news is, when I boot up the pc, the power turns on, the fans turn on, but that's it!, only CD ROM and cpu fans...
Hello
Open up the case,after unpluging pc.
Remove memory sticks one at a time.After you removed one try pc again.
If it boots up normally then you know that memory stick is bad.Also check your keyboard by unpluging and pluging back in while booting up.
More then likley this is bad memory.
Mar 24, 2011 | Dell Computers & Internet
Hi! I get Supermicro U2 server with X5DPA-GG MBO. Cpu and memor modules are ok, but when I turn on server I get long error beep. I took manual and saw that's overheat problem (or should be). But server...
This sounds like a video controller issue. Try booting with a different monitor. Ensure the cables are connected to the motherboard correctly (fans/power/led indicators). Try booting off of a single stick of RAM. Otherwise you may need to check the warranty status and RMA the motherboard to have it repaired/replaced.
1 beep: circuits reset - ready to power up
5 short, 1 long: memory issue
8 beeps: video adapter issue
Feb 21, 2011 | SuperMicro X5DPA-GG Dual Xeon/E7501/FSB...
I just purchased a new cpu and plugged in my Acer X203H monitor that i have only had for around 3 months and when I turn on the computer and monitor, the monitor power light flashes orange and blue and has...
Sounds like your PC is diplaying out of your monitors range. Try pressing f8 while booting up to get safe mode. then turn down the video resolution to display what your monitor can handle. Good Luck.
Nov 20, 2009 | Acer X203H bd Monitor
Not booting
listern to what ur beep codes say. one short-fine, one long & two short beeps-video failure, so on ... ... ...
May 02, 2009 | Dell Dimension C521 PC Desktop
ASUS P5KPL-AM CPU fan connection.
You should still be able to connect the 3 pin connector of the fan to the 4 pin connector on the mobo, the keying tab is offset so that you cannot connect it to the wrong pins.
If you still don't want, or can't connect it there, simply go on the Bios (press delete after you turn on your computer) and you will find an option to monitor CPU fan speed.
If you need any more help, let me know
Alex
www.CAS411.com
Mar 28, 2009 | Computers & Internet
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
No booting
did u chk the power cable to monitor ?
replace the power cable wd tht of the tower or cpu if cpu glows then ur monitor neds to be repired
May 22, 2008 | Intel Motherboard
Dell OptiPlex GX240 PC Desktop Logo
150 people viewed this question
Alun Cox
