Question about Fagor 5HA-196 X Single Oven
Manual for Fagor 3H-125 Oven
I bought Fagor 3H-125 Oven 4 years back and has not stated using it. i lost the manual now. Can anyone help
  • Anonymous Mar 22, 2009
    i lost manual 3h-125x
Fagor oven has error code F06
I cleaned the smoke filter, took of the top cover, in front of electronics is the brown smoke sensor. I took of one wire off the sensor, started the oven (beware of not shortcutting anything) the f06 error message had disappeared. I put back the wire, mounted the top cover and the oven functions like new.
Nov 28, 2012 | Fagor 5HA-196 X Single Oven
I have a Fagor 5H 196X oven and whenever I set the automatic timer it cuts off after 3 seconds and the automatic shut down symbol appears does anyone have any ideas
Please find here our reply from the customer service of Fagor America:
This problem could be confusion over how to properly program an automatic cooking function. First, you must program the cooking duration, then you must program the time of day you want the food to be ready. Sometimes customers think they need to program a “start time” and an “end time” versus a “duration” and an “end time”. Please, make sure you are doing both steps correctly. Also, you should be aware that this clock works on the 24-hour principle (military time). I know that sometimes this confuses people as well. If both of those are okay, then it probably has a defective clock. If that is the case, please feel free to call our customer service:
UNITED STATES OF AMERICA and WESTERN CANADA: Please contact ADCO Customer Care at 1.877.743.2467, or by email at: fagor@adcoservice.com
EASTERN CANADA: Ontario, Quebec. Please contact A.G.I Service Inc: Telephone: 450-963-1303 or by email at: nruel@agintl.qc.ca.
If you have any other questions do not hesitate to contact us at: infoappliances@fagoramerica.com
Best Regards,
Aug 22, 2010 | Fagor 5HA-196 X Single Oven
Fagor oven will not regulate its temperature, once
From the symptoms you describe, I would say the oven thermostat is faulty, and in need of replacement.
This is the control you regulate the temoperature with.
Hope this helps.
Dec 15, 2009 | Fagor 5HA-196 X Single Oven
I have a Fagor oven 2H1261 model electric short circuit
try checking oven switch could be shorting or usless
Sep 29, 2017 | Ovens
Nesco 18 qt. Roast-Air-Oven/ Manual
You could contact the manufacturer they would have one. Nesco www.nesco.com 1-800-288-4545
Sep 28, 2009 | Ovens
Oven Indicator states - ''Help''
We had the same problem. hold both MODE and SET down [ about 10 seconds or more ] till other functions come up . This worked for us
I'm looking for a users manual or copy
email compbuilding@hotmail.com
Mar 28, 2009 | Ovens
Fagor overn doesn't heat
I had a similar problem - turned out the knob on the left by the clock was set to automatic instead of manual.
Dec 15, 2007 | Fagor 5HA-196 X Single Oven
Fagor 5HA-196 X Single Oven Logo
1,036 people viewed this question
Top Fagor Ovens Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Bill Boyd
Are you a Fagor Oven Expert? Answer questions, earn points and help others
