Question about Canon PowerShot SD1000 Digital Camera
Lens error on SD1000 Canon but opened lens and made it worse!
Hi.  I have a SD1000 Canon camera that was working just fine until yesterday when it gave me a lens error restart camera.  I tried different things but nothing worked so I opened the top part of the lens and out came the different parts of the  lens, including the springs that hold the plastic shutters that cover the lens when off.  I dont know how to fix it and have no money to buy a new camera.  I was looking for a picture of the inside of the lens to try fixing it myself with no luck. Please let me know what I can do and how much it may cost.  Thanks
  • jayroh2020 Jan 05, 2009
    i have the same problem...i turn the camera on and get lens error...restart camera. i've only had this camera for a couple months and do not want to buy a new one...need help
  • 33 Answers
Lens error means that either it was dropped on the lens or the lens just failed. You could be looking at a $90-$120 repair
Posted on Dec 31, 2008
'"The lens of my cannon
This is basically the infamous Canon "E18" error, which has been around for quite a while.
I would type out my own suggestions but since it's such a common error I'll just direct you to a nice long list of solutions already compiled elsewhere: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 01, 2011 | Canon PowerShot SD1000 Digital Camera
Lens Error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 28, 2010 | Canon PowerShot SD1000 Digital Camera
I am having power supply and lens problem with a canon sd1000 digital camera. its not working with the battery inside and the lens got stuck and was not closing and now it is open but the camera is off and...
I am afraid you have the notorious lens stuck problem. If you google "canon lens stuck" or "canon lens not retracing" the results will be in millions. Canon's quote for repairing this issue is well over the cost of the camera itself. However all is not lost. It may be just dust. You can try to clean the lens contacts with isopropyl alcohol and see if resolves the issue. I have previously suggested placing the camera lens on the edge of the table and hit it with moderate force to force the lens back into the slot and I was surprised to know it worked for a lot of people!
http://www.fixya.com/support/t240817-camera_error_e45
Might be worth a try after getting a quote from canon?
Dec 25, 2009 | Canon PowerShot SD1000 Digital Camera
Canon SD1000 lens error
Turn off the Camera, remove the Battery pack, then press and hold the power button for 30 seconds.
Reinsert the Battery, then buzz around the lens for a few times then check if it works. Make sure that the Battery is fully charged.
The error message indicates that the lens is not able to adjust itself.
Oct 23, 2009 | Canon Cameras
Lens error, restart camera
i had the the same lens error restart camera problem for almost a month.  If you haven't already, try restarting the camera with the sd1000 in the view pictures setting.  This may allow the lens to retract into position. Next, with the lens extracted, try looking down on the camera from the top to see if the lens is angled downward in any way.  If it is, this means it is jammed into place on one side.  Simply use your fingers to slightly push the lens into proper position.  If you hear a pop, you should be in business! hope this helps!
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
Canon Powershot SD1000 Lens Will Not Retract
This is a huge recurring problem with Canon cameras. check out this website-give it a minute to load. You will see literally thousands of people with the same experience.
http://e18.bitnet.cx/comments.php?full=1
Aug 18, 2008 | Canon PowerShot SD1000 Digital Camera
Camera not taking pictures
Sounds like you might have a lens error developing. Look for error messages on the screen. A clue is abnormal performance by the lens in tracking and zooming in and out.
May 06, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
185 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
