SOURCE: I need an electrical diagram of the snapper lawn tractor
Hello:
Try this Site Addy;
>>You can View a Breakdown of the Mower at this Site Addy; http://www.snapper.com/manuals/ . Enter your Model Numbers in the Box Provided and Click Find Manuals. Select Illustrated Parts List from the Manual List Provided. Now Download the Manual for Online Viewing.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
I have disconneted the battery to try stopping the engine but the mower still runs, not sure if the problem is electrical or fuel related. i've checked ignition switch, belts and all micro switches. Can anyone shed any light thanks.
