Question about Sonic Impact Technologies Super T 1-Channel Amplifier
Did RCA plug short cause channel loss on Super-T amplifier?
I put a DIY interconnect on the Super-T amplifier. The plug shorted as the screw down for the center connector rotated and made contact with the barrel when I installed the plug. The channel stopped working when I installed the plug and no longer works. A change of interconnects does not help. Could the shorted plug have caused the channel to fail?
    Genius:
  • 1,175 Answers
Hi...
If the plug in question is an input, No the channel isnt damaged but you'll need a new connector. If it's an output , it may have shorted the amplifier output.
Posted on Jan 02, 2009
Klh powered sub woofer
Low level inputs are designed to take signals directly from an amplifier's "sub out" connections. That way the KLH amplifier will use those signals to produce sound and the volume can be balanced between the main amplifier and the sub amplifier using the sub's volume controls. Depending on your amplifier and sub, that is the best way to connect them. However, be careful running the RCA cables since the low levels are more subject to interference. Keep the runs as short as possible and use high quality shielded cables for the interconnects.
Aug 26, 2014 | Audio Players & Recorders
We have a pmp6000 mixer hooked up to our ep 4000 and b1800 and b2520,it seems we can only hook up the amp to the mixer into either mono's 1 and 2 or the main 2 however not in main 1 with full...
MAKE SURE the cables you plug into 1/4 inch mains are TRS plugs, and not mono cables (TS). The main output 1/4 inch jacks are TRS balanced outputs and if you plug mono (TS) cables that shorts out the ring connector reducing the power by 6 Db. USE ONLY TRS balanced cables for interconnects !!!! Also read my tip on Fixya regarding PMP mixers. If you use 1/4 inch SPEAKER cables or adapters, if you short the SLEEVE of channel A output to ground you can pop the channel A amp. The TIP of channel B is the hot BUT the SLEEVE of channel A is the HOT. The ttip I posted explains why this is and it isn't mention in the Behringer documentation.
Aug 06, 2011 | Behringer EUROPOWER EP4000 4,000-Watt...
One channel blown
Unfortunately there is little we can do directly. The output transistors are likely to be shorted on the bad channel. This is not a DIY repair for most people. Expect a repair bill in the $80 range for parts.
Dan
Apr 24, 2011 | QSC PLX2502 Stereo Power Amplifier...
WHAT DO IT MEAN FOR MY AMP TO READ DIAGNOSTIC
The diagnostic light, for this particular model, means that there is either a short circuit on the loudspeaker leads or there is an internal amplifier fault that is causing a DC offset. In order to determine which, disconnect all RCA and speaker leads while keeping the +12 volt, power ground and remote leads connected. Now turn the amplifier back on, and if the diagnostic LED lights up, the amp has an internal fault. If not, plug the RCA cables back in and reset the amp. If it goes into diagnostic now, the problem is with the input (either bad cables or a faulty head unit). If the amp is fine with the RCA cables plugged in, repeat the process with the speaker cables (one at a time). When you plug in the faulty speaker wire it will put the amp into diagnostic mode.
Mar 06, 2011 | Hifonics XX-Hercules Car Audio Amplifier
I recently hooked up my vizio soundbar to the center output on my RX-V465. I simply hooked up the speaker wire on to the receiver and soldered RCA plugs to hook up the soundbar. Now my receiver randomly...
hi ,
check the is there is any short inside the RCA connector. if so this problem can occur.
also if the center amplifier stage have any problem it will get shut down. may be the output transistor of ur center amplifier get damaged. check the same
ok
Dec 27, 2010 | Yamaha RXV465BL 5.1 Channels Receiver
Looking for shorting pins for technics model su-v98-km1
You can make it by yourself. All you have to do is to shorten a pair of RCA cord to about 2 inches and then plug them into the
shorting pins hole.
Sep 17, 2010 | Technics SUV500 2-Channel Amplifier
It goes right to protect mode when i plug in the rcas
plug one at a time to check for a short on either the right or left channel. if both do it, then try another rca cable. if that does it too, then unplug your speaker outs and plug your rcas back in and check. get where i'm going with this. process of elimination. if nothing helps, then there's a short in your amp.
Jul 05, 2010 | SPL Dynamics Z2X-820 Car Audio Amplifier
Lost one channel on the Sonic Impact Super-T amp
YES!
The output device on that channel will have blown. Look at the output device for that section by following the leads back from the plug, Anything with a heat sink on it is the best bet for the fault.
Dec 31, 2008 | Sonic Impact Technologies Super T...
AMP Issue
check for pinched wire causing ground loop. Screws and seats are easy culprits. If you have a spare RCA... or can borrow or buy a cheap one... run it from the radio to the amp without routing the wires in the car and test.
Possibly could be hitting metal behind radio. Be sure to secure and tape wires.
Nov 09, 2007 | Legacy LA1490 - American Series 2 - 1400...
Sonic Impact Technologies Super T 1-Channel Amplifier Logo
104 people viewed this question
Top Sonic Impact Technologies Audio Players & Recorders Experts
 Grubhead
Grubhead
jscuin6
Tom Chichester
Are you a Sonic Impact Technologies Audio Player and Recorder Expert? Answer questions, earn points and help others
