Question about ASUS MB P5E3 PREMIUM/WIFI-AP X48 RT (90-MIB3L0-G0AAY00T) Motherboard
P5E3 WiFi-Ap MB won't load XP
I have a new P5E3 Wifi-AP MB with a 2.8G P4 CPU.
I am trying to load Windows XP Pro, but keep getting the
STOP 0000007B message.
I have tried loading the drivers supplied with the MB thru the F6 function. (Makedisk chipset, Makedisk jmb). I have tried with and without these drivers but still get the same message immediately after the 'Starting Windows' text from the Setup CD.
I have a single 500Gb SATA drive and am configured for IDE mode in the BIOS.
I have partitioned and formatted the drive using a bootable DiskGenius CD, so I know that the drive is good.
Any suggestions?
  • 142 Answers
Make sure that the drivers you are using can support XP Pro because im not sure if they can. Also, double check to make sure that you have all of the necessary drivers and other things to make it run. Thanks and happy new year.
Posted on Dec 31, 2008
    Sergeant:
    Champion:
  • 304 Answers
Have you try to use a different installer?
do check and use another windows installer,.
  • 837 Answers
IDE mode is not always supported by the XP install .. I would make sure to load the SATA drivers using the F6 at the prompt ..
Otherwise load to an IDE drive .. then mirror to the sata .. then hook up the SATA and finish .. its a cumbersome work around but it does work
P5k-e front pannel audio not working
Make sure you check that the front audio cable is connected properly on your motherboard. You can see how it's supposed to be hooked up and where it is located on page 2-32 in either of the manuals I have linked up for you below. And if you haven't already make sure you have the correct audio driver installed.
Drivers & Downloads for ASUS P5K-E/WIFI-AP:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KEWIFIAP/#download
Manual #1:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K-E/e3216_p5k-e.zip
Manual#2:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K-E/e3501_p5k-e_wifi-ap.zip
Jun 14, 2012 | ASUSTeK COMPUTER Asus P5k-e/wifi-ap Lga775...
Samsung corby ii- no wifi ap found
How to no wifi ap found?
Mar 15, 2012 | Cell Phones
PC HANGS ON BOOT
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Feb 18, 2012 | Computers & Internet
Drivers
Hi..
You can find your asus motherboard in asus website, just visit the asus site then search the model of your motherboard, if you can see now the model you can start to download the drive.
Regards
PCmania
Jul 10, 2009 | ASUS P5Q3 Deluxe/WiFi-AP @n Motherboard
Windows 2000 Pro
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
alkllklju4
Apr 14, 2009 | ASUS M3A32-MVP Deluxe/WiFi-AP Motherboard,...
Asus p5e3 freezes at POST.
Hi David,
Maybe you could buy a new CMOS battery and replace the old one..
Might be worth a try..
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | ASUS MB P5E3 PREMIUM/WIFI-AP X48 RT...
I have a new P5E3 Premium WiFi-AP MB. I have fitted one new 500Gb SAT drive to SATA1 connector I am trying to load Windows XP Pro, but each time I try, I get STOP 0000007B message. I know the drive is OK...
Why do you have your SATA configuration set to IDE compatible if you're using an SATA drive? You only need to do that if you have an IDE drive in the system in most case. Try setting your BIOS to failsafe mode and see what happens.
Dec 31, 2008 | ASUS MB P5E3 PREMIUM/WIFI-AP X48 RT...
Wlan dosent connect to net work
Make sure that your wlan is on, search your wifi ap broadcast by doble click wlan icon under the top corner desktop, double click search if wifi ap appear you can connect by doble click connect bar, if wifi have security you must write or set the security setting like wifi ap by consult with admin wifi. In order to best conection you must in range of wifi signal not so far from your ap.
Sep 26, 2008 | Sony Computers & Internet
Intel upu ucode loading error
While starting computer a msg appear " intel upu ucode loading error" after pushing F1 computer get start my computer having ASUS mother board P5BMX/WIFI-AP and intel core2duo procesor Please help
May 19, 2008 | Computers & Internet
ASUS MB P5E3 PREMIUM/WIFI-AP X48 RT (90-MIB3L0-G0AAY00T) Motherboard Logo
26 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
