Question about Gateway Computers & Internet
Computer is dead will not turn on
Took the computer into a service tech he told me the motherboard was fried
  • Derek Fuller
    Derek Fuller May 11, 2010
    ....and you don't believe the tech??? ....
    President:
  • 948 Answers
When you buy a new motherboard, make sure and get one that accepts the same processor and memory, and video card that you have now. It is not terribly complicated to replace the motherboard but if you have never done it before be prepared to spend a few hours reinstalling your operating system and all the correct drivers for the new motherboard components. Also make sure you get a board that will fit in your computer case, not all boards are the same size.
Posted on Dec 31, 2008
LAPTOP does not turn on. only fan runs.
Things to check first.
1. Make sure you have a new BIOS battery installed. Some computers will not start if the battery for the BIOS is dead.
2. The CPU may have overheated and no longer works. I lost a CPU and everything was dead.
3. A dead motherboard can also act in like manner.
Sometimes something will come loose on the motherboard causing a direct short which of course fries the motherboard and probably the CPU. Dropping a laptop can shake things loose.
My Daughter had this happen with hers. It was a 800 dollar HP Compaq and I had a heatsink come loose on my HP Compaq which fried CPU AND Motherboard. Beware of HP since they bought Compaq.
Jan 25, 2011 | Intel Computers & Internet
My computer got wet and now it doesn't work. Do I need a new motherboard? Water poured into it while it was off, so I told everyone it was down. A friend tried to ''fix'' it by turning it on. Now it just...
At least the motherboard is fried. My guess is that everything in it is dead since when a motherboard dies a nasty death like this it drags down everything with it.
Lesson for the future: if there's even the slightest whiff of water near some sensitive electronics then disconnect it from the power until you are ABSOLUTELY sure the water is gone.
Jun 14, 2010 | Computers & Internet
I recently dropped my HP Compaq Presario laptop V5209US and took it to Fry's electronics for diagnostics. I wasnt able to open the CD door after it was dropped. They told me it has a ''bad optical drive...
If everything else was working fine (until today) and just the cd-drawer would not open, a damaged systemboard (or motherboard) is highly unlikely.
1) What does "not turn off"? The Laptop or the CD drive?
2) To check what is exactly damaged you could power down the laptop and remove the CD drive entirely. Then power on the laptop. If everything works fine only your cd drive was damaged.
Jun 30, 2017 | Computers & Internet
Problem with quickplay won't play dvd's
may you need to install video codec. was't youre os? xp or vista?
Jul 23, 2009 | HP Pavilion dv9000z Notebook
No power
Just open ur P.C cabinate and look when the Power supply is on in ur mother board then there is a green light in ur Mother board ; is it on ??
If the LED is on then I hope ur mother board is ok yet.
Then I think there is some connection prob on the pushing button on the cabinate.
Check it if it is not then u have to replace ur mother board.
Jan 02, 2009 | Gateway 3200XL PC Desktop
Computer is dead will not power up
I have Nokia Cell phone 6070 which is Sofware Completly Walk out (Remove) Should you tell Me about what is problem ansd what Divece are atteches within.
Dec 31, 2008 | Computers & Internet
Dell dimension 8300 no power
Bad news:
In my experiance you have a fried mother board.
Question are you getting any display from your monitor - if you are there is hope - if not the same thing that took out the power suply has probably fried the motherboard.
The only other thing I would sugest is to flash the BIOS - either locate JP1 or remove the battery (looks like a whatch battery) and cross the terminals with a screwdriver - re-install the battery and see how it goes.
Point: No display = no motherboard.
Good news is that the RAM, Procesor and other components are probably good.
Nov 11, 2008 | Sunon (16-02-006) Fan Kit
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Computer problems
it sounds more of some legal issue than a technical one.. ask someone in that field..don't waste my time.
Aug 22, 2008 | Intel Motherboard
Won't boot up.
anilkpa, I don't know if your tech ran a diagnostic or was able to.
It doesn't hurt to take it somewhere else for a 2nd opinion. If the mobo is dead I'd do what the tech advised.
Question by FJDM,
"SO WHAT DO YOU DO THROW IT OUT?"
Definately not. Did you buy this new ? As is ? What does your warranty state ? Usually a store will offer a limited warranty and extra avail thru the manufacturer or if you pay more, right thru the store. 15 days seems a little short in any case and you reported the problem to them BEFORE that period.
It sounds like what you're dealing with is a customer service issue, bypass that technician and ask for the Customer Service Manager.
Jul 09, 2008 | Toshiba Satellite M35X-S349 Notebook
Computers & Internet Logo
62 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
