Question about Plumbing
Shower not hot
How can I increase the temperature to which the shower valve allows the shower to run hot watter. The tap water in the basins is hot, and the showers in all other bathrooms run pleasantly hot. But in on bathroom, even when turned fully to hot, the shower water is not adequately hot. The shower plate is a Grohe Europlus II
    Problem Solver:
  • 18 Answers
There is a handle limit stop under the handle. Remove the handle with an allen wrench and you should see a plastic piece with a tab on it fit into the assembly. Remove it and rotate it slightly to allow more travel in the handle and reinsert. You will have to test it to see if it allows enough hot water to mix in. If it is still not warm enough repeat as needed. Once you have the water at a comfortable temperature reinstall the handle and enjoy.
Posted on Dec 31, 2008
Water temperature has reduced even on maximum setting
check tap had a shower myself that would start hot then 3 minutes later hot was cold! then hot after 5 minutes.
I turned off main tap on meter, Undid tap fitting on shower found the washer was worn but also the tap fitting was seized could not turn it for full movement. You could soak the tap screw fitting in CLR and pull apart and use a tap grease on the screw thread or just buy another tap fitting. I discovered most of my tap fittings had calcium build up in them. But I replaced the shower tap valve thingy as it was really seized up.
Nov 22, 2015 | Home
Could my grohe thermostatic shower be letting cold water into my system? Some other taps run cool but the shower is running OK temperature
If you have single handle facute one bad cartridge in the system may be acting like a mixing valve and allowing cold water to mix with hot not allowing water to get hot enough .
Mar 10, 2015 | Grohe Water Heaters
I have a hudson reed Twin Concealed Thermostatic Shower Valve. It was working fine for a couple of years. My brother used the shower and adjusted the water temperature valve but since then the water has...
Sounds to me the diffusor is stuck or broken in the position to allow only hot water through it.Looks to me tou have a mixer valve on it. Might have to replace it.
May 31, 2011 | Hudson Reed Home
I do not have enough hot water from my shower head. I have plenty of hot water in my bathroom and kitchen sink. What can I do to remedy the problem?
the problem is the hot/cold mix is set wrong ---
remove the water control handle to expose the mix valve -- you should see a small set screw that will either increase or decrease the travel of the hot water valve. --- sometimes instead of a set screw there is a little pop off plastic set ring,, pop off and set to a more advanced travel.
this will increase the amount of hot water that flows to the shower head and the bath tap.
c...
Jan 20, 2011 | Grohe Freehander Adjustable Shower Head...
Hot water tank does not work when shower is on, it does however work when the faucet in bathroom is on. It quit working in the shower about a month ago.
  1. COLD MIX, HEATER DEACTIVATES
    If inlet water temperature is over 70°F due to geographic location, water maybe very hot out of the tap. This requires a lot of cold water to be added with it in order to attain a useable hot water temperature. The addition of too much cold water will overpower hot water demand from the tankless water heater. This slows the flow within the tankless water heater, decreasing it below activation point, which shuts off the heater. The end result is nothing but cold water coming out of the outlet. See: TWH E2-04 Overcoming fluctuating temperatures [PDF].
  2. FLUCTUATING WATER PRESSURE
    If the water pressure in the home is erratic and the water flow is not consistent while a tap is opened, then the temperature of hot water will fluctuate. The minimum water pressure for the home should be 30psi or greater. For people on well systems the minimum pressure range is 30-50psi. The use of a pressure reducing/regulating valve is an effective way to maintain constant water pressure to the water heater. Watts brand 25AUB- ¾" or N35B-¾" pressure reducing/regulating valves or equivalent is suggested.
  3. CHANGING FLOW RATE
    Major changes in flow rate can adversely affect the output water temperature of the heater. Increases from one major fixture running to multiple fixtures running at one time can cause the temperature to fluctuate. Stay within the heater's specifications. See: TWH E2-03 Outlet temperature vs. flow rate [PDF].
From the Bosch website.
Good Luck,
Gary
Dec 16, 2010 | Bosch PowerStar AE125 AE125 Whole House...
Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Apr 26, 2010 | Hansgrohe 06358620 Pressure Balance Valve...
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
Aug 09, 2009 | Water Heaters
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
Plumbing Logo
655 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
