Question about Microsoft Xbox 360 Controller
Wired controller Where do i put it? Where does it go on the consol?
    Problem Solver:
  • 7 Answers
If it's wireless no. Just turn on ur 360 and press that X button on the controller. Hold it for like 2 seconds. For wired ones, just hook it in that think slot on the side.
Posted on Dec 31, 2008
My ps3 controller isn't charging what should I do ?
First, you need to troubleshoot if it's your system, wire, or controller.
Testing the controller:
Try plugging the wire into another port on the PS3, or into something else to charge it. Try charging it on a friend's system, with his wire, to see if it's your system. If it doesn't work, your controller or battery is bad.
Testing the battery:
Put your battery into another controller, see if it will charge on your friend's PS3 to test it. DO NOT put another battery in your controller: If the controller is shorted, it could ruin your battery!
Testing the Console:
If your controller charges on your friend's PS3 with his wire, try to use their wire on your system. If that works, it's probably your wire. If not, try other ports as I said. If none of the ports charge it (but it charges on your friend's, there's a problem with the voltage or amperage.
_______
If it's your system: It may symbolize a short life left of your PS3, not not for sure. I would still avoid plugging anything into USB you don't want to risk getting destroyed. You can still charge your controller with certain wall chargers, but only certain ones have the circuitry for a "handshake" the PS3 needs to charge.
If it's your wire: Get one from the dollar store should work.
If it's your battery: Getting one one eBay may be cheaper than replacing your controller.
If it's your controller: I prefer wired controllers personally, anyhow... for everything but the Wii, of course. You're going to need a new one for the PS3. You may want to save your battery for a later time or need.
Dec 11, 2015 | Sony Playstation 3 (PS3) Console
I have a Wii game system model No. RVL-101 (USA) how do u get it to work
ok so u start to plug all the wires in the TV.theres a sensor that u need to put in middle of the tv.the sensor is like a rectangle and very lite its supposed to have a wire that has to be plugged in the wii not the TV.
after that its time for your controllers.you need to have at least one controller to play wii.you need to put two batteries at the back of the controller.then click the power button and you'll see the 4 lights light up,but then after seconds there supposed to be 1 light lit up.when your done than click the power button for the wii.for the controller to work u should turn on the wii before the controller.Then the easy part take the cd(game)and put it in the wii.
Dec 06, 2013 | Nintendo Wii Console
My psp's control sometimes stops working and I don't know how to fix it
On the back of your control there is a small hole. Get a thin piece of stiff wire and put in that hole and it will reset your controller.
Apr 05, 2013 | Sony PlayStation Portable (PSP) Slim...
I recently got a free Nordictrac NTL1095.0 C2050 from my neighbor. it seems to be stuck in demo mode. no buttons work even when trying to get out of said mode. The console will beep when key is put in but...
well the reed switch is working but sounds like board or both check voltage coming to the console. wire harness. not sure but if it reads low controller iisue
Mar 16, 2011 | NordicTrack Exercise & Fitness
My xbox wont sync with controlers and no lights show up it will work however with a wired controler or keyboard wtf is wrong with it, my xbox is apart right now iv taken the light pad off and put back on...
On the frount of the xbox by the memory card slots there is a little white button. If you press that were your green light on your xbox is on the fround of the console little bars will spin. Ontop of your controller, next to where you put in your plug and play there is also a little white button press it and both the controller and the console should link. =] if fails keep trying. =]
Nov 05, 2010 | Microsoft Xbox 360 Console
When washer started stopped working then showsa code of F1
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My PS3 controllers will not link with my console even with the attached wires. I have just linked into the internet and had a system upgrade.
you need to reset the controller, get a pin (or something sharp) and put it into teh hole in the back of your controller, if your not sure which hole, try them all hope this helps you
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
Synch controllers to PS2 console
I don't know what type of controller you have, but all the wireless PS2 controllers I've used come with a receiver that you put into the controller port, and then you should be able to use it. The wired controllers, of course, you just have to plug in.
May 10, 2009 | Video Game Consoles & Games
Controllers
The wires of your controller maybe faulty.
I suggest that you must have the controller repaired by someone who specializes on game console repair (not just by someone who knows controllers). Some problems may require you to use a soldering iron to remove the faulty parts and replace it with new ones or a multi-tester for testing and removing certain segments of the cable if there is wire problem. Chances are you could get other working parts damaged or hurt yourself, which is not your goal.
Dec 29, 2007 | Sony PlayStation 2 (PS2) Console
Xbox 360 wireless controller
change your controllers m8 sounds like they faulty i have had no probs
Oct 24, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Controller Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
