Question about Jenn-Air JGD8345 Gas Cooktop
Downdraft cover and grill grates
Hello:
Are the downdraft cover and grill grates supposed to have rubber bushings on the bottom corners, as do the regular burner grates? Without thes rubber "feet", they slide all over the cooktop surface and the downdraft grate has actually fallen into the filter area several times.
Thanks in advance for your knowledge! Tim
I bought mine new from HD. Neither the dd cover nor grill grates have bushings on them. however thats a good idea.
Posted on Jun 12, 2009
  • Emily Marshall
    Emily Marshall May 23, 2014
    Thank you for the post. I know thathttp://www.patentproducts.com.au/ is a good resource. You can call them to ask their experts your questions.
Need new electric cooktop to work with downdraft CV2236N-01.
never heard of one needing downdraft usually updraft . gas maybe but not electric
Apr 12, 2014 | Maytag MGC5430 Gas Cooktop
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
My new home already has a hood vent for the range. I have a gas Jenn air downdraft range. I prefer to use the hood vent as the downdraft is not very efficient. Do I have to connect the blower on my range...
The poupose of either is to eliminate any smoke created by the range or grille and move as much of the cooking odors to the outside. I wouldn't use both at the same time, but if the hood is vented to the outside, it would be just fine to use only the hood. Aregular cleaning will be necesssary. The downdraft has limits as to the distance it will efficiently exhaust air. Flex hose should not be used. And excessive bends or vent length, cuts into the efficiency.
Oct 29, 2009 | Jenn-Air JED8230 Electric Cooktop
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
Nov 25, 2008 | Jenn-Air JED8430 Electric Cooktop
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Order in black w/matte finish grates & downdraft cover
No. If it is really important order the grates and downdraft cover as replacement parts. This will be expensive probably around $200 - $300.
May 25, 2008 | GE 30 in. Profile JGP989 Gas Cooktop
JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn-Air JGD8345 Gas Cooktop Logo
380 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
