Question about Cyberhome CH-DVD 300 DVD Player
Changing to PAL format...
...also, I tried changing the video setting since the DVD output was now B&W! I chose something I didn't understand under the PAL dropdown and now, there's no picture at all and spotty sound! So, now I can't even see the setup screen to change it back. Is there a way to reset the thing? Thanks!
I have the same issue i don't know the solution to ur original problem of B&W.. I think you might have unknowingly changed the "Video Output".. don't worry...to change it back.. do the following steps 1) Switch on dvd player with no disc 2) wait for few secs and press setup on remote 3)press -> (rt arrow) once 4) press enter 5) press down arrow twice 6) press enter 7) press up arrow once(or twice) 8) press enter hopefully this shud work..
Posted on May 07, 2007
I incorrectly entered PAL in video format setting now screen is stuck and says change resol utio n but can not change it need help!!! protron pd-dvr100 dvd recorder
I'm sorry for the difficulties you're experiencing as the Video output settings on the DVD Recorder is set incorrectly. Please perform a power resetting by following the below steps and check the operation.
To perform power resetting, unplug the DVD Recorder from wall outlet for more than 5 minutes and press and hold the Power button for more than 15 seconds. It will discharge power from all circuit and move the Recorder to factory default.
Thanks for understanding. Please let me know if the issue persists.
Nov 23, 2011 | Protron PD-DVR100 DVD Recorder
I have a Philips DVP-3010 DVD player which I purchased in Europe and thus it was set to PAL video output mode. Connecting it to a US television (which understands only NTSC) and playing a DVD produces a...
Check that the TV doesn't have the option to display PAL transmissions. It might be able to do it via any of the connectors. Otherwise your best option is to find a TV that can indeed convert both signals, or get a converter box.
Apr 04, 2017 | Philips DVP3020 DVD Player
Dvd or video only produces black and white pictures
just go to your dvd seting and chose the output setting you will see ther an 3 diferent output NTSC-PAL-AUTO chose auto if automatic output doese not work call a service center for your dvd.
Aug 11, 2010 | Sony SLV-D950 DVD Player/VCR
My new "panasonic" dmp bd80 not support the PAL DVD format and can't play some DivX disks. Can you give some solution to solve the problem?
Check the dvd player settings. Try and switch the dvd player itself to NT instead of pal.
Some newer DVD Players also play videos in the MPEG-4 ASP video compression format (such as DivX) popular in the Internet, as well as the RMVB video compression format.
Check any settings on dvd player to switch format output, or check tv settings so it accepts all formats.
Nov 23, 2009 | Televison & Video
Set up video output
Pal output will only work when it is plugged into a pal tv. The only way you can restore is to use the remote to put the settings back to ntsc without using the display. That should work. If you don't have a pal tv you should never change devices to run on it, because it can damage your tv set. The scanning lines are very different between the two systems.
Aug 14, 2008 | Cyberhome CH-DVD 300 DVD Player
I have a philips DVD home theatre system HTS8100. Its fine except that NO dvds play in synch. I have checked them on my normal DVD player & they are fine. The synch button on the remote sometimes fixes...
Synch problems on Philips machines can be caused by the video output setting.
Usually there are 3 options for video output:
  • PAL
  • NTSC
  • AUTO
PAL & NTSC force playback in that setting, regardless of DVD format, and sometimes cause a time delay in the conversion.
Try changing this option to AUTO. IF you have a modern TV, it should allow both PAL & NTSC playback.
May 12, 2008 | Televison & Video
Ps3
you might want to try changing the settings settings just go to sound settings>audio output settings and choose the type of cable you're using sfter that select automatic and press X. if that doesnt solve the problem may be you accidentally chage the BD/DVD audio output format. is locate in BD/DVD Settings change both BD/DVD audio output format (HDMI) and BD Audio Output Format (optical Digital) to linear PCM or viseversa try both to see wich one works.
p.s. it can also be a problem with your sound/ hometheater system.
Apr 25, 2008 | Sony Playstation 3 (PS3) Console
No video in my philips dvd622
The black and white picture is caused by only 2 things.
  1. You are trying to play back an NTSC disc in a PAL dvd player (or the other way around)
  2. Your DVD player is set to NTSC when it should be set to PAL (or the other way around)
You will find options for setting PAL or NTSC in the setup menu under Video.
Apr 03, 2008 | Computers & Internet
Alpine dve-5207 & tmx-r705
Hi Allan,
To my understanding, both are inter-compatible to either NTSC or PAL.; the player will auto detect what format the disc is and auto-switch over. As the manual says, "DVE-5207 automatically changes the video output signal (NTSC or PAL), according to the disc." On the other hand, the TMX-R705 needs manual settings (2 ways):
1. NTSC and PAL can be directly switched when the DISP on the TMX-R705 remote button is pressed for at least 2 seconds; or
2. On the TMX-R705 remote, press the SETUP button, press the DOWN or UP button within 10 seconds and select AUX 1 SIG. or AUX 2 SIG., press the LEFT or RIGHT button within 10 seconds to set the selection.
Just an after thought, pls verify that your DVD Region number is either 2 or ALL. Additionally, you can verify the color format the unit is using (as well as the disc) by pressing DISPLAY during playback on the player.
Should this not be corrective, perhaps you need to check the grounding/wiring and the interconnections cables.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 14, 2007 | Car Audio & Video
Black & White picture
There can one of two problems here. Either your DVD player's output is set to NTSC and you are attempting to play it through a PAL (European) TV, or you are perhaps using the SVHS output incorrectly. The solution is to access the player's setup menu and ensure the video output is set to your standard (PAL or NTSC). Hope this helps!
Feb 14, 2007 | Philips DVP642 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
48 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
