Question about ASUS MB P5E3 PREMIUM/WIFI-AP X48 RT (90-MIB3L0-G0AAY00T) Motherboard
I have a new P5E3 Premium WiFi-AP MB. I have fitted one new 500Gb SAT drive to SATA1 connector I am trying to load Windows XP Pro, but each time I try, I get STOP 0000007B message. I know the drive is OK as I have partitioned and formatted it using Disk Genius from PCbeginner bootable CD. I have the SATA configuration set to IDE compatible within the BIOS. I have tried adding drivers to Windows set-up thru the F6 function, but I don't know which driver would be needed. Since I only have one disk, I am not using the RAID function. The CPU is a 2.8G P4.
  • raymond_fren Dec 31, 2008
    Within the BIOS there is a SATA configuration which can eb set to Disabled,Compatible or Enhanced AND there is a Configure SATA as IDE, RAID or AHCI. RAID is inappropriate for a single drive and I don't know what AHCI means
    President:
  • 948 Answers
Why do you have your SATA configuration set to IDE compatible if you're using an SATA drive? You only need to do that if you have an IDE drive in the system in most case. Try setting your BIOS to failsafe mode and see what happens.
Posted on Dec 31, 2008
  • Dick
    Dick Dec 31, 2008
    Go into your BIOS and as you exit, select "Load Setup Defaults". That is how your go back to failsafe mode.
PC HANGS ON BOOT
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Feb 18, 2012 | Computers & Internet
Sata isnot reconized in bios nor will it install xp on a sata drive it starts to load all files then when to enter to set up xp home sp-3 the board is new been shelved then it gives windows cannot be...
Look up the specs. on the mb and find out if it supports sata1 or sata2 drives.
Your motherboard should have four sata ports and you may want to change to another port.
Also, you may need to format this sata drive, booting from the ide drive. Windows takes a long time to format but may be the only answer.
Last, make sure your bios settings are sata as raid.
Hope this works for you, its a pain.
Nov 19, 2009 | PC Chips MB PCCHIPS K8T800 M860 V1.0...
Drivers
Hi..
You can find your asus motherboard in asus website, just visit the asus site then search the model of your motherboard, if you can see now the model you can start to download the drive.
Regards
PCmania
Jul 10, 2009 | ASUS P5Q3 Deluxe/WiFi-AP @n Motherboard
Blue screen
Blue screens on a system with an activated copy of Windows are usually the result of hardware changes. I would take out or unplug everything except the boot drive. If it boots OK now, put things back in one at a time and reboot. I know it is time consuming, but if you do 2 or more at a time you don't know which one is causing the problem. I would take pictures of the insides the way they are now so there won;t be any confusion. Pictures are easy to delete, but hard to create if you don't have one of the connection you are unsure of two or three days from now.
Oct 29, 2017 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Asus p5e3 freezes at POST.
Hi David,
Maybe you could buy a new CMOS battery and replace the old one..
Might be worth a try..
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | ASUS MB P5E3 PREMIUM/WIFI-AP X48 RT...
ASUS P5N32-SLI Premium/WiFi-AP
they dont sell them u need clal asus .com ask f they have one 5 10 bucks ok or else just dont use it alsoways install i o shild 1st then mobo
Oct 13, 2008 | ASUS AI Lifestyle P5N32-SLI...
New sata 500 gig hdd - ST3500320AS SD15
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
May 17, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Boot Failure
i am assuming you have allowed the bios to detect that there is a different hard drive fitted as it will be looking to boot from an non existent drive. If you have fitted a new HDD with an operating system already on it then you will have to repair windows as its a change in hardware. If you cant get the bios to see the drive then the motherboard has an IDE or Sata connector problem.
Sep 13, 2007 | Computers & Internet
ASUS MB P5E3 PREMIUM/WIFI-AP X48 RT (90-MIB3L0-G0AAY00T) Motherboard Logo
88 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
