Question about Refrigerators
Hi, I have a whirlpool side by side refrigerator that will not cool. The light comes on and the fan blows but it will not cool. I tested the compressor relay and it looks to be good. Both the refrigerator and freezer sides will not cool. Therefore I felt that the compressor might be the problem. Is there a good way to check to be sure that the compressor is definitely bad? Or am I looking at the wrong thing in order to find out what the problem is. Thanks Ron
    Novelist:
  • 161 Answers
Unplug the Ref for 15-20 min, plug it back in and listen for the compressor to start running. You will have to be behind the Ref so you can tell if it's the condensor fan or the compressor running.
Not running, replace the relay. $20-25 you can get a universal start relay and if that won't get it started then the compressor is bad.
Also, another compressor check is with an OHM meter, check for a dead short, touch one lead to ground and the other to each of the three post on the compressor. Any reading on the meter indicates a short in the compressor motor.
Running but not cooling. Take the back wall off in the freezer so you can see the evaporator coils. They should have a light coat of frost over all the coils. No frost or partical covering means it's low on coolant.
Posted on Jan 01, 2009
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
My whirlpool side by side is getting warmer. Freezer was up to 45 F yesterday, today 55 F, Refrigerator getting warmer too. Fan on freezer and refrigerator vents blowing, but isn't that cool. What's...
check and clean the condenser coil under the ref , remove the back to the ref if the compressor is real hot you need to put a fan behind the ref for a couple of hours until the compressor cools down then plug it back in.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
The Freezer and refrigerator stopped cooling. The fan blows but only warm air is coming out.
might be the compressor,compressor relay or overload or the sealed system may have a leak. call an appliance repair company. not recommended to repair yourself
Jan 31, 2010 | Whirlpool GS5SHAXN Side by Side...
Freezer and refrigerator no longer cooling
Sounds like the start relay,capacitor and overload need replaced. If you would like my assistance let me know, Thank You, Sea Breeze
Nov 27, 2009 | Refrigerators
Whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
Nov 12, 2009 | Whirlpool ED5FHEXMQ Side by Side...
No cooling at all in fridge or freezer side. light still on in fridge and circulator fan blows in freezer
check you air damper
you should feel air near the top with the freezer door closed
mkae sure your air retrun behind the drawers is clear
Oct 10, 2009 | Whirlpool GS 6 SHEXNT Side by Side...
Side by side whirlpool refridgerator GD5SHA is no longer cooling
Your refrigerator has an Adaptive defrost board inside the fresh food compartment that is the number one reason I think your refrigerator is not cooling. Reading your post you mentioned this just suddenly began to happen. Can you hear the compressor running? Is your fans blowing inside the freezer and below the refrigerator? Can you feel warm air coming from back and under refrigerator or cold air blowing inside freezer? Click on link below and enter your model in search feature. You will see 36 similar choices, just make sure you choose one that has refrigerator beside the model number. When you get to the correct page choose photo 10 control parts click it and you will see the Adaptive defrost listed in photo as item 6. Let me know those other things I asked in this message so I will be able to help you better, Thanks Sea Breeze
click be low link enter model GD5SHAXLB01 in search feature
http://servicepartstec.blogspot.com/
May 20, 2009 | Whirlpool GD5SHAX Side by Side...
Refrigerator side walls are hot
these heaters in the wall come on when the house is hot to protect the fridge .there is a energy switch in the fridge that says ( if moisture appears) shut this off
Apr 17, 2009 | GE GSS25LGM Side by Side Refrigerator
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
