Question about MTX RT202 Car Audio Amplifier
Feedback/maxing out speakers.....
Basically when i turn my stereo on it seems as if everthing is fine. at medium volume it sounds really blurry . and when i turn up the volume on either the headunit or the gain on the amp it starts to feedback and it eventually builds up untill the subs are maxed out. if the volume is completely down and i slowly turn the gain up it does this as well at about half way. i've tried moving the ground and replaced the rca cables and the speaker wire going to the subs. any help is GREatly apreciated !
  • robert stinman
    robert stinman May 05, 2007
    oh also. when i connect the ground it sparks a little bit. i dont know if that was normal or not. but. yeah...
Its connected directly to the head unit
Posted on Aug 12, 2007
  • 113 Answers
Starting from amp,what is the rca connected directly to. headunit or adoption?
Posted on Aug 09, 2007
SOURCE:
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
My stock stereo speakers go in and out. most of the time lately the speakers are real low and your have to turn up the volume almost to max to hear them decently. and then the bass and mid isn't working....
My speakers in my 2003 Silverado started to fail at about 5 years old. I just replaced them with all new speakers. They would come and go erratically and sounded horrible.
Sep 11, 2013 | Logitech X-530 Computer Speakers
The sound in the left speaker goes on and off on rough road. turn the volume up to max it works. Turn down 2-3 and no sound
IS A LOOSE WIRE CONNECTION TO THIS SPEAKER ---- WHEN ON FULL VOLUME THE HIGHER CURRENT COMING TO THE SPEAKER KEEPS IT PLAYING .......
CHECK THE CONNECTION ON THE BACK OF THE SPEAKER ---- MAYBE UNHOOK AND RECONNECT AGAIN ......... IF NOTHING CHECK THIS SPEAKER CONNECTION AT THE
STEREO REAR .............. YOU WILL FIX THIS
Jun 29, 2011 | Car Audio & Video
I inherited a technics SL-6 turntable system and a very old sears audio by fisher am/fm stereo receiver along with 1 pair of kenwood ks-401ht front speakers and cant get any sound. I have the technics...
Your connections seem to be right.
Let's distill this down to its simplest configuration... does the onboard FM produce sound? If not, nothing will.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Apr 17, 2011 | Audio Players & Recorders
Describe your Magnavox Stereo Mini System FW36 Problem My speakers that came with the stereo dont really work. only when I turn the volume all the way up I can hear the music, but the sound is really...
Yes.
Apr 16, 2011 | Philips Audio Players & Recorders
Volume Level on Memorex 9299M 4-in-1 Turntable System Way Too Low
It's the nature of the all-in-one turntable beast to be low fi and low performance. Too much volume and vibration would feed back through the turntable.
It does have a Line Out that you could slave over to REAL electronics and speakers.
May 23, 2010 | Memorex Nostalgia Turntable and Stereo...
Tinny sound from L-310 SW's
This might be helpful. Most stereo receivers have 2 sets of speaker outputs, A and B. Each have outputs for left and right speakers. On the front panel of the receiver, there should be a switch to turn on/off speaker A/B. When using both A and B, (a set of speakers on each A and B) you will lose a bit of volume.
Another possibility is, if the speaker cable length to your covered porch is a long distance from the receiver, you will lose some power from the receiver. Try using a thicker gauge speaker cable for longer cable runs. Try 14 gauge or 16 gauge.
Apr 06, 2010 | A D S L310 Main / Stereo Speaker
Speaker will not turn on
Actully the problem is your speaker which is shorted. The speaker assembly or the one who crashed out always, when you excited the volume to max it feedback to amplifier Ic to cut the fuse blown. The amperage goes up and sent to either left or right amplifier power supply.
Even you replace the fuse with a new one it will repeat the situation and story.
later sooner it will damage more.
r_ic7
Nov 28, 2008 | Alesis M1-Active MkII Main / Stereo...
Sound feedback
Are those add-on speakers, not clear on that? Feedback is almost always a problem involving speakers and microphone being to close together or mic being to hightly modulated. It is possible that power lines being to close could induce a hum of varying severity.
Dec 21, 2007 | Philips SPC 900NC Webcam
MTX RT202 Car Audio Amplifier Logo
78 people viewed this question
Top MTX Car Audio & Video Experts
Mike Duncan
Mike Duncan
Philip Armitage
Pierre Laplante
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
