Question about Whirlpool Refrigerators
Loud noise each time the fridge completes a cooling cycle it ends with a loud" clang "or maybe bang but the same noise each time. No other symptons
  • 1,543 Answers
When the compressor stops, the movements of the internal components are normally absorbed by the internal spring supports. If a spring breaks, etc., the inner moving part will contact the outer case and give a knocking noise or two when it stops. You can make the compressor (even a new one) do this by giving it a shake. The compressor will most likely run for years this way with no performance problems. It is rather expensive to replace a compressor, (especially for only a noise issue) so most people just live with it or get a new refrig and use their old one as a second refrig in a basement or where ever. Please don't bother to rate this, as anything but a Fix-Ya drops my score.
Posted on Dec 31, 2008
Dometic banging noise
Not real sure what could be banging and clanging as there aren't really any moving parts. There have been some reports of gurgling sounds coming from the cooling unit and also water pipes 'hammering' when the pump is on.
Mar 09, 2014 | Dometic RM2852 Refrigerator
Hotpoint ffp187b loud noise from appliance
Where is the noise coming from? The front, back, top, or bottom? Is it a bump, thump, bang, clang, or rattle? Does the sound happen at regular intervals or randomly? It could be the compressor bushings going bad, causing the compressor to bang around.
Mar 25, 2013 | Hotpoint Refrigerators
My LG Intellowasher M-1480FHD has started making a loud banging noise on the final spin. It also wouldn't end the spin cycle at the end of the 30min wash
the banging noise while in the spin cycle will more than likey be worn shock absorbers and will need replacing.
Aug 31, 2010 | Washing Machines
LOUD CLANGING NOISE
also check all your suspension bushings make sure they are all good. spare tire holder maybe? make sure none of the rear leaf springs are broken. also make sure all the bolts holding the bed down properly. make sure it isnt your tailgate either... could pretty much be anything. just make sure you bushings are good and everything is tight.
Jun 20, 2009 | 2000 Chevrolet Silverado
Spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
Feb 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Fridge w/ freezer on top. LOUD banging noises.
I think the banging means the compressor is shot. (more like a load "clunk"). I had the same noise on a dehumifier.) I dont' think replacing a compressor is a DIY, and doubt it is economically efficient. But I leave that to the specialists to comment on. Check Craig's List in your area - you can get a good deal for a few hundred bucks.
Also, the "clanging noices" is probably the fan blades for the air circulator that moves cold air from the freezer to refrig compartment. Check the online manual for your model (exploded parts view) to see where it is located and if it is readily accessible by taking out a few screws inside the refrigerator. Might be more than one fan - open the door when it happens and see if you can locate where the noice is coming from. This is a plausible DIY - I did it only my old fridge - replacement parts were cheap. But you might even be able to just reallign the fan blades so they don't clang.
Oct 26, 2008 | Refrigerators
Noisy refrigerator compressor (?)
This is a compressor problem, and chances are there for this to worsen if not attended promptly.
Feb 06, 2008 | Refrigerators
Water dispenser and ice maker
you got it replace the water inlet valve but make sure it is bad first ...................The loud noise you hear maybe caused from too much pressure on the valve turn the pressure down a little and try again
Jan 10, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
311 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
