SOURCE: Oven Doesn't Reach Set Temperature
Check the element for burns/wholes this was problem for our. Easy fix and part is about 35 to 40 dollars.
SOURCE: frigidaire oven model FEB500CEBI TEMPERATURE PROBLEMS
The short and simple answer is yes you do.
SOURCE: Kenmore 30425 Oven will not reach target temp
the ignitor is moast likley bad, look for a hot spot on the ignitor showing a open on the filament.
SOURCE: I need to calibrate an electric oven
Probably. There is often a key sequence that will enable a calibration mode. We need the full model number to find the tech info, or you can probably find it in the tech sheet which is normally taped on behind the control panel.
SOURCE: Oven runs much hotter than set temperature.
Sounds like you need a new oven thermostat or get an oven thermometer and by experimentation draw up a new heating range for the oven dial.
