Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Grinding Noise My LCD TV made a loud popping noise last night. Now there is a medium "grinding" noise (sounds like a grinding wheel) and the TV does not turn on.
  • siwinski51 Jan 01, 2009
    I was *hoping* it was something easily replaced like the cooling fan. The posted solution gave me the guts to actually take the back off my TV and check. Unfortunately, it is not the fan :(. The sound was actually a "sparking" coming from the front center when the screen was trying to come on. I believe the "do it myself" solution is out of the window. Does anyone have any idea what a repair might cost me?
Sounds like you have a problem with the cooling fan
Posted on Dec 31, 2008
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Last night our TV made a loud popping noise then the picture went out. We still have sound but have trouble turning the TV off. What could this be and is it fixable? Thanks, Anne Marie Orcutt
Question shows it is Vizio L32 lcd tv and symptom shows back light inverter board for defective for some reason and loud noise would be popping of any chip on inverter board.
Shopjimmy..com has replacement boards of that model on reasonable price and local tv repairman will replace defective board after checking/ testing the tv.
Hope these info will help.
Thanks.
May 11, 2011 | Vizio L32 32 in. LCD HDTV
The bulb has been replaced within the last 3 months and everything has been working fine. When I turned the TV on just now there is a buzzing sound sounds like a motor is running and continues to run for a...
Ur colors wheel it dead.It spinning of it axes.The noise u hear it the grinding of the colors wheel.There no colors,big buzzy loud noise,or grinding noises.In any kind of DLP tvs that produce the last 10 years they all have colors wheel's.Hire a Tv repairman for this job.Because it require alot of taking out of machanical parts,even can come to the colors wheel part to replaced.Many people made a mistake think it was easy,cost them alot more $$,because tv's tech. don't like fixing other people mistakes,and blunders.Give them a head aches tries figure out what the customer did.
Apr 10, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Picture is black and white
Does it sound like thin grinding noise?
The color wheel is very common problem. Color wheel for this model is about $100 to $150 plus labor.
Nour BMI
Feb 18, 2010 | Samsung HC-P4752W 47" Rear Projection...
Have a 04 dodge with a driver side grinding noise that comes and goes. It started after I got my truck stuck in the snow. I thawed out the front end last night, and now its worse. It comes and goes while...
C V Joints can make a lot of noises. Sounds to me like you either bent the inner fender or if it is plastic you may have pulled it loose and it looks normal but it is just sitting in place with the push pins out of their intended holes. When you turn and or hit a high speed it hits the wheel/tire. Try putting on some gloves and then pulling medium strength on the fender well and surrounding areas to see if that is the problem -
Feb 03, 2010 | Dodge Ram 1500 Cars & Trucks
RCA HD50LPW164 turned on TV made a pop
the loud pop you heard was probably a capacitor blowing its top. The grinding noise is likely high voltage arching that was occuring due to rising voltage since capacitor isn't there to smooth it out.
Nov 02, 2009 | RCA HD50LPW164 50" Rear Projection HDTV
I have a SONY WEGA flat screen, last night while watching tv, there was a loud pop in the tv, now the LAMP light keeps flashing and there is a grinding sound coming from in the set. No Picture, no other...
The loud pop was a capacitor blowing.
The light is flashing because either power board or ballast board is faulty.
Using the TV in this conditions can cause further damage.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
You can find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 04, 2009 | Sony WEGA KDL-42XBR950 42 in. LCD HDTV
Samsung DLP loud vibrating noise
The color wheel is the most common problem in DLPs that cause noise. To determine the cause: Turn the set off. If the noise goes away after about five seconds, then, the problem is the color wheel. If the noise goes away one to two minutes after shut off, then, the problem is a fan. You can find an Authorized Servicer in your area that can tell you the price of repair, by clicking on the Samsung link: http://www.samsung.com/Support/ServiceLocations/index.htm
Apr 22, 2007 | Samsung DLP HL-P5663W 56" TV
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
257 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
