Question about Best Data Products Best Data BizView BV200 Graphics Card - ATi RV280 240MHz - 128MB DDR SDRAM - PCI PCI Graphic Card
Screen resolution of 1080p sharp lcd
I am getting a fuzzy screen that does not fill the entire monitor
  • 1 more comment
  • Anonymous Jan 02, 2009
    Hi, I am using the ATI bizview 200
    windows res set to 1920x1080 that's the highest it will accomodate.
    Is this because of the graphics card?
  • Chip Loon Ng
    Chip Loon Ng May 11, 2010
    i forgot to add what is the resolution that you have set from the windows?
  • Chip Loon Ng
    Hi, what is the graphics card model you are using?
    Champion:
  • 254 Answers
Set the resolution to the native resolution of the monitor
less makes it look fuzzy
Posted on Jan 01, 2009
My monitor is fuzzy in internet
Fuzzy on the internet and everything else or fuzzy just on the internet? check for monitor resolution and see if you have the screen resolution set right. If you have the resolution set too low, the screen can appear more fuzzy if the aspect ratio is not set right.
Jun 04, 2014 | Samsung SyncMaster 2333SW 23" LCD Monitor
Screen is fuzzy
For best display on LCD monitor, you need to set the PC video resolution to the native resolution of the monitor, this monitor native resolution is 1280 x 1024 @60Hz.
Mar 29, 2010 | Acer AL1714 17" LCD Monitor
Turn on 1080p
You do not turn on the 1080p resolution, the TV will display what resolution it is being fed with, just like your PC monitor, you adjust the resoluiton at the PC not the monitor. The source determines the resolution.
Jan 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Acer Monitor Display of text and image is not sharp
This might seem obvious, but is your video card output set to the native resolution on the monitor? If not, it will look fuzzy. Try 1680x1050, if you don't know the monitors native resolution.
No need to use anything higher than a 60hz refresh rate either.
Mar 29, 2008 | Acer AL2216WBD LCD Monitor
Words are not clear
if its a crt monitor dump it,if its a lcd monitor try changing your screen resolution from display properties,or on the monitor check the brightness and contrast controls.
Dec 26, 2007 | Hyundai ImageQuest L70S 17" LCD Monitor
SETTING
The Aquos is capable of 1080p which is the best current HDTV resolution - awesome!  The exact resolution is 1920x1080 with a 60Hz refresh rate.
Its also very capable at upscaling 720p inputs.  I've done various tests and visually there is practically no difference when watching a regular DVD and having the DVD player do the upscale, or letting the television do the upscale.
If you are connecting a computer then its a little more complicated...
If you are attaching a computer to the television then if the video card in your computer is capable of 1920x1080 at 60Hz then this would be perfect.  Personally I would rather use 720p rather than drop to 1080i as the drop in resolution isn't noticeable from 4 feet whereas interlacing causes me to get a headache after a while.  (LCD / Plasma interlacing isn't as bad as old CRT monitors that used to use interlacing - so not everyone will get eye strain / headaches from it)
The television is also good at showing other computer resolutions too although you'll need to make sure "overscan" is turned on which can cause some bits of the computer desktop to disappear off the edge of the screen...
I spent quite a while getting the DVI->HDMI working - to be honest I'm not entirely sure it was worth it and the results from a regular older style monitor connector is pretty similar...  If your graphics card can't handle the required resolutions - then it may well be worth a new card as HDTV output cards are available pretty cheap...
Nov 17, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Screen resolution
1680 x 1050 at 60 Hz is the ooptimal resolution and the only one that will not be fuzzy.
http://support.dell.com/support/edocs/monitors/2005FPW/En/about.htm#Specifioications
press command - shift - a to bring up the Applications folder. Then open System Preferences. Click on Displays, from there you should be able to adjust the resolution
Oct 10, 2006 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Best Data Products Best Data BizView BV200 Graphics Card - ATi RV280 240MHz - 128MB DDR SDRAM - PCI PCI Graphic Card Logo
251 people viewed this question
Top Best Data Products Computers & Internet Experts
David Payne
David Payne
Are you a Best Data Products Computer and Internet Expert? Answer questions, earn points and help others
