Do you offer any help about a monitor that goes black and says "no input" or something to that effect....?
  • 585 Answers
I take it this really has nothing at all to do with speakers?
If the monitor is giving this indication randomly check the data cable at both ends to make sure it is well connected. Bear in mind if the monitor consistently does this after a given period of inactivity, then it is actually the result of the screensaver or power settings in the computer turning the monitor off. When this happens, the monitor will show a "NO SIGNAL" message for 5 seconds or so before turning itself off. Then of course, tapping a key on the keyboard or moving the mouse will bring back the display. This is a good thing and is not an indication of any trouble.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Jan 01, 2009
  • 238 Answers
You must properly connect that VGA cable from monitor to built-in VGA serial port of the motherboard or connect it to the Graphics card in your cpu unit if you are using a graphics card and not the built-in VGA serial of the motherboard. Then lock it.
Posted on Dec 31, 2008
  • Jarish Castañeda
    Jarish Castañeda Dec 31, 2008
    Hi sir, correct me if I'm wrong, you are referring to a monitor display right? Drop me a comment so I can assist you.
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
BLACK MONITOR...INPUT NOT SUPPORTED
This is the resolution problem. Pls reduce the resolution . Right click any where on the desktop and click on properties there. a popup appears just choose Setting there . there you will find the option of Screen Resolution .Just Slide the pointer toward less litlle till your problem resolve.
Sep 04, 2009 | Acer AL1916W 19" LCD Monitor
HP vs17e My screen went black for a few moments and when it
Switch off and on your PC and hold down the F5 key and this should bring up your PC in Safe Mode. If this fails, then find a PC repair shop to replace the power supply.
Mar 22, 2009 | Computers & Internet
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
Dec 07, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
Monitor goes black but green light on
i think this is the power supply i have same product and problem. i have completely dissembled the monitor and found taht there are three boards power/ input/ video conversion. there are four wires on the right side that go to the inside of the screen. well if you find where to get a new psu the me know
Nov 01, 2008 | Westinghouse L1975NW Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
the 12V is for speakers.. the 245bw takes regular 120V AC (same cord as your computer)
the buzzing is annoying, though. i don't know if it's a "feature" or just a side effect.. ie, if i could take the case off and poke around, i would. 4 times out of 5 it's some dumb piece of tin reverberating from a transformer or something..
Dec 03, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
LCD Monitor Goes Black during Use
I had the problem sometimes, but then I connected a second computer to the analog input and found out, that the screen didnt turn black but switches between the inputs on an on.
I found out that the "input" button seems to be short or damaged, as the behaviour was invertable by pressing the button. I blew into the button some times (a very naive solution, yeah) but it worked, the switching stoppped.
Oct 17, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
Screen black
Bill, It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 06, 2007 | Samsung SyncMaster 910T 19" LCD Monitor
 Grubhead
Grubhead
