Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Sears said i need a new power assy
Is there any alternatives or anywhere i can go to get this part cheaper than 215 dollars? For everything that is adding up on this it almost feels like i could just buy a new tv.
  • amanda8810 Dec 31, 2008
    Thank you soooo much! The cheapest i could find the part was $215.40.. Thank you!!
  • 4,234 Answers
You can order the power assembly (part number JT23831) from tritronicsinc.com for $140.32. Upon the return of hte bad module, you will get refunded $25 making the final cost $115.32
Hope that helps,
Dan
Posted on Dec 31, 2008
Battery replacement costs
That sounds quite high. Have you tried stores such as Batteries Plus, Auto Zone, etc.? They will most likely have what you need and most install them for you.
Aug 23, 2012 | 2007 Dodge Charger Daytona R/T Sedan
I have an oven Electrolux (Frigidare) Model PLEB30S8CCC, it will not heat up properly when turned on. The bottom heating element is not working. It OHMed out OK, but is not getting voltage when the oven is...
you're not getting 240 volts down to the element,you could have a burnt wire,a bad relay in the clock assy. or a bad fuse or breaker in the house.you can pull out the stove,unplug it,remove the back panel, check for any burnt or loose wires back there, if it looks good plug it back in and where the cord connects to the stove check to see if you have 240 volts going to the machine,make sure nothing is touching anywhere before you plug it in.if you get 240 there check power at the element and see if you're getting power to the element,if not unplug it,follow the wires back and check them for breaks.have you noticed anything else going wrong or not working normally?if you have 240 going to the machine,but no power going down to the element you could have a bad clock assy.this is the part number that comes up on the sears site 318010700R and it's around 160 dollars,i'm not saying to buy this computer board and put it in,you have to do checks with your meter to make sure first that power is coming into the machine,to the computer board but not down to the element and that there are no broken or burnt wires anywhere or call in a tech if you have to,also how old is it and what shape is it in before you have to start buying expensive parts for it,also there should be a tech sheet on the stove that will tell you how to check things out on it.good luck and hope this helps and be careful doing checks with it plugged in
Sep 06, 2011 | Frigidaire FGF326AS Gas Kitchen Range
I can't find the plug and cable that came with the machine. Is there anywhere I can buy one? Thanks
If you are in the USA (110V) then try this website
http://www.sewingpartsonline.com/husqvarna-viking-215-sewing-machine-parts.aspx
If your country is 240V then you may need to purchase the power lead from a UK website or your local Husqvarna Viking agency.
Apr 26, 2011 | Husqvarna Huskystar 215 Sewing Machine
Oven gets to hot, unable to control oven temperature
you could either have a bad sensor or the clock assy. is bad,there's a computer board in with the clock assy. that everything runs through.the part number is W10177195 and it's around 200 dollars,you can try the sensor first or read it out with a meter,part number is 12001655 and the sensor is around 35 dollars.there should be a tech sheet on the back of the top console or down near the bottom draw,it will tell you what the sensor should read out at on the meter,sounds like the clock but start with the sensor,it's cheaper then you have to decide if you want to sink 200 dollars into this or put it towards a new machine.good luck.
Apr 11, 2011 | Whirlpool GW397LXUS Stainless Steel Gas...
I have a broken wheel stud on left wheel of a two-wheel drive 2002 Envoy. How do I replace it?
TAKE VECHICLE TO SEARS AUTO CENTER OR ANY TIRE WHEELS BRAKE ALIGNMENT SHOP THEY CAN PRESS OUT THE STUD WITH OUT DAMAGING WHEEL BEARING.AND PRESS YOU IN A NEW LUG NUT STUD.PROBABLY CHARGE YOU $25.00 DOLLARS.
Jun 12, 2010 | Cars & Trucks
I have a hotpoint wf740 which has had a bad smell coming from it, i took the front off the bottom, and unscrewed the filter which then snapped when i pulled it off as it was full of coins. (my dad gave me...
I think this is your pump and filter.
http://cgi.ebay.co.uk/hotpoint-indesit-drain-pump-and-filter-assy-new-sealed-/220605267643?cmd=ViewItem&pt=UK_Home_Garden_Washing_Machines_Dryers_Parts_Accessories_ET&hash=item335d193ebb
I spent a very long time looking for this. I recommend you look in your local phone book business pages for Appliance parts / supply and have your model number WF740 in hand. These complete pump assys appear to be cheaper than just the filter. You can order the new pump / filter assy and just use the filter for now.
Thanks for using FixYa,
Kelly
May 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
Transported Roland KR-177, toppled - pedal assy needs replacing
Good grief! FInd a tech that knows what he is doing. You can replace the plug and/or the jack. Each is a few dollars at most. You can even do it yourself. If you can see where wires went just buy new parts. They are probably available even at Radio Shack.
Oct 03, 2009 | Roland Music
95 dodge neon, why alternator belt broke and it is a new belt and how u get the alternator out put in new one in
the belt was too tight.. if this happens, you might also damage the bearings of the alternator assy...
remove the alterenator brcket/adjustment bracket... then remove the bolt connecting the assy to the engine... replace the alternator assy. then reverse the process to installl the new assy.. and tightened.... be sure to leave some play to the belt.... to prevent overstretching
Jul 19, 2009 | Air Tools & Compressors
ILO MP3 Player
You can buy the mp3 player on ebay for about 20-30 dollars that is cheaper then buying the screen would be most likely. You could buy the one gig for 10-15 dollars and use that screen.
Jan 21, 2008 | iLO (2 GB) MP3 Player
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
29 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
