Question about Sony Playstation 3 (PS3) Console
My browser isn't working!
I tried to move my ps3 to a location where I would have a better net connection, but when I turned it on, everything was normal, but the browser (where you find video, network, games, etc.) was not showing up on screen. When I tried to turn it back to stand by mode, the green light flashed for nearly half an hour before I decided to use the switch in the back. I tried just rebooting it, but I had the same problem. I moved it back to its normal spot, but I had the almost the same exact problem, except now the icons for the browser appeared as well as the clock, and the loading symbol at the top right corner is there also. I can connect controllers, load and eject discs, and hold in the connect button so that "turn off the system" and "turn off controller" appear, but without the browser, I cannot watch movies, play games, or do anything else. If it matters, my ps3 is an 80 gig and I've had it for a year and a half with no problems whatsoever until now. Someone help!
I fixed this problem, but I'm still not entirely sure what went wrong. If I'm not mistaken, my wireless connection to the internet was causing it. I took my ps3 to my friend's house to see if he knew anything (who does not have wifi by the way) and we turned on the ps3 and it worked just fine. To be sure, I switched the internet connection settings to wired before I brought my playstation back home. Unfortunately, it only gave me the option to restore the hard disk. Somehow, this didn't delete all my game data, but I may have just gotten lucky. I can't gaurentee this will work for everyone, but I seem to have fixed the problem by terminating my ps3's wireless internet connection
Posted on Jan 01, 2009
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
I have an error code 80130182, what does it mean n how do I fix it?
80130182 means it can't connect to the internet. Here are the steps you should take.
1. Unplug everything from your router.
2. Unplug everything from your modem, even the cable.
3. Remember where everything goes.
4.Turn off your PS3.
4. Plug it all back in and turn it back on.
Mar 14, 2011 | Sony Video Game Consoles & Games
Cant get online when i run a test it fails on playstation net work then afterwards says you have been disconnected from media server
If you are using a router, the problem probably has to do with the router. In order to find out, disconnect your PS3 from the router and plug it directly into you modem. If your modem is not near your playstation 3 then move it close to the PS3. The modem plugs directly into your cable line so there is a good chance that the television you play your PS3 on has a cable connection. One you have connected your PS3 to your modem, press the reset button on the modem. Turn your PS3 on and go directly to your network settings. Click on Internet Connection Test (do not bother trying to set up a connection manually) If you are getting a connection then you are ready to go.
Thank you!
May 18, 2010 | Sony Playstation 3 (PS3) Console
TWO PS3 ON A LINKSYS WRT54G
Log into your router, type routerlogin.net in your PCs web browser and configure a static IP for each of them. Also if your using wire-less its probably better to have at least one wired, both if you can. I've played my ps3 on a wireless-N router that was about three feet away and I lagging while playing killzone 2.
Sep 11, 2009 | Sony Playstation 3 (PS3) Console
Lost connection when trying to play online
hard wire the ps3 to the router first to see if connection is lost.............if not it's interference between ps3 and router
Aug 01, 2009 | Sony PlayStation 2 (PS2) Console
8001000b error
1. Locate the PS3 MAC address number: Settings - System Settings - System Information
2. Open the software controlling the router. This is usually done my typing the router's IP address on your browser. ie http://192.168.0.1
3. Locate a tab for FILTERS
4. Slelect MAC filters.
5. Enter the PS3 MAC address from previous step as an allowable MAC address.
6. Save entry. At this point router will reset itself.
7. Go back and set up the wireless connection on PS3. Select all settings automatic or EASY as the case maybe.
It is also important to go through the connection settings to make sure everything is correct:
http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Hope this helps!
Apr 05, 2009 | Sony Playstation 3 (PS3) Console
Turning on PS3 causes home wireless network to stop working
I have the same problem. My router is located about 1.5 feets from the PS3 and when I turn on the console my wireless network barely works. Something I did was change the frequency of the wireless. It was working in channel 9 and now it's on channel 3 with no problem.
Feb 14, 2009 | Sony Playstation 3 (PS3) Console
Ps3 network issue
First, wire your ps3 directly to the modem, cycle (reset) everything then try the normal connection procedures. You should only have the console, and the modem in the equation for testing purposes, this will let you narrow down the problem. You must turn everything off so that all of the information on both ends will auto refresh.
Dec 16, 2008 | Sony Playstation 3 (PS3) Console
How do I get my PS3 Online?
right fist of go on settings on the ps3 menu then go to network setting then click onsettings and connection status list take a note of all the ip addresses and servers then go to internet connection on the same menu and click on scan then click on your router name and then lick onenter ur wep key if u av 1m but if u dnt then cck on none then press right then go o custom on the address setting then manual on ip adress settings type in all ip address and servers and stuff then click on auto on the mtu dont use proxy server enable unpn click right then press x to save ur settings then test connection thn hopefully this works for u m8 cheers arsenal_07
Mar 24, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
