Question about Kenmore Elite 45986 Front Load Washer
Tub spins out of round
I have a Kenmore Elite He3t. The tub spins out of round, therefore it shakes and vibrates. The feet are adjusted and secure. You can visually see the tub spinning out of round. Is it the tub bearings?
  • 1 more comment
  • CinTexas Jan 14, 2009
    Mine is also spinning off, causing it to make some noise. How do I replace the bearing? Thanks.
  • scott9864 Jan 21, 2009
    Tub is spinning out of round. how do i replace tube bearing or is ther some kind of adjustment that can be made first?
  • mbordner Mar 01, 2009
    Washer shakes during spin cycle. This did not occur prior to tipping it to paint the wall. It is level in both directions. Could tipping the machine destroy a bearing??
  • Kenmore Master
  • 19,396 Answers
When that happens it is usually because of a drum bearing problem, have it replaced before this damages more parts.
Posted on Jan 02, 2009
Kenmore Elite Model 44836
Check that the feet are level to the floor as this may cause the vibration. Also set the machine to wool mode this then knows what material you are putting in the machine then should cycle to that material.
Thanks J
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
The washer shakes to much and make to much noise
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Jul 21, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore elite washer has a very loud banging noise when it spins
U will need to remove the washer drum and check the washer drum stablizers and the washer drum bearing, do this to see what is wrong and how far u need to go in this repair.First open the door and spin the inner tub to make sure the tub spins freely, if not you have big problems.
If it does then remove the lower front panel. There are 3 screws along the very bottom of this panel that you can remove and then the panel will come off. Check to make sure the shocks are not cracked or broken under the tub. If not and the unit just recently started shaking a lot, then replace the shocks as they are probably worn out. If it's been shaking since the day you've gotten it and it just seems to have gotten a little worse, then purchase Shake Away pads which are specifically designed for front load washers to sit under the feet of the washer and reduce vibration dramatically.
May 07, 2010 | Washing Machines
Wash machine vibrates moving several feet on fast spin cycle
If the suspension is still flexible, any unbalanced load will cause this. If it is accompanied by the tub striking the inside of the stationary tub, one of the suspension points may have failed.
I would remove the lower rear panel and watch the movement (with a good light) of the outer tub while a helper pushes the inner tub to its extremes to see if one of the points is 'unhinged.'
Jan 29, 2010 | Kenmore Washing Machines
Kenmore Elite tub shaking badly
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 10, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite make a funny sound during a drain spin cycle
it either is the something in the pump or something in between the inner tub and outer tub
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Front loading machine abnormal strong vibration on the spin cycle
Check the tub rollers or wear plates.
May 30, 2009 | Kenmore Washing Machines
Tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Oct 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He3T problems, won't drain
The machine knows when there is water left in the tub and will not function properly because the level switch indicator is still open.Ok, to simplify this ,you have a clogged pump and if there is no access into the machine from the front then look at the back to see if there is.Open the panel and remove the hoses from the pump and remove what is caught in it.Also look into the ends of both the 2 hoses.Don't wash RUGS,MOPS,COIN MONEY,NAILS,JEWELERY,UNDER WIRE BRA'S,OR ANY THING THAT DOESN'T BELONG IN THE WASHER,cause these little things don't make it past the pump,therefor washer leaves water inside and error messages start rolling.
May 25, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
595 people viewed this question
Sal De
fordexpert
Robert Rankin
