Question about Dishwashers
No water entering the dishwashet - Dishwashers
    New Friend:
  • 16 Answers
Check electic water inlet valve screen on lower left bottom of dishwaser, follow the inlet water line to locate the valve, turn off power, and water, reremove inlet water hose, and valve hose, check inlet screen for sand, wash as needed. re-assemble in reverse order,
Posted on Dec 19, 2012
SOURCE:
H/f error code maytag mfw9600sqo washer
No water detected entering the machine. So it could e several problems. If water is entering that means the machine control oard can not see that happening. It could e a faulty control oard, faulty wiring, faulty water flow meter. You didn't say if water was entering or not. If not water is entering, make sure the house supply is one both faucets, make sure the water valve screens are not clogged.
Jan 29, 2016 | Maytag Washing Machines
Whirlpool GHW9400PL1 - hot enters instead of cold water.
has ur machine seen a technician b4? now try to interchange the 2 wire for the hot water valvet to the cold and the cold to hot........
Feb 26, 2012 | Washing Machines
No water enters the dishwasher when its turned on
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 23, 2010 | Bosch SHV46C03 Built-in Dishwasher
GE PROFILE PTS22LHPARWW ICEMAKER NOT WORKINNG
change or remove filter
change control valve
change valve on copper water ine
change copper water line
check input pressure to unit
25? 25? anybody know what is the minimum water pressure supposed to be entering the refrigerator icemaker?
Oct 23, 2009 | GE Refrigerators
The cold water enters the machine a just above a
You may need to replace the water inlet valve then.
Jul 03, 2009 | Washing Machines
No water enters on rinse cycle
I was partially wrong on my diagnosis. No cold water enters on either the wash or the rinse cycles. I also heard odd noises from the inlet valves. I realized the cold water valve was not opening. I've ordered the mixing valve and plan to replace it as soon as it comes in.
May 20, 2009 | Kenmore Washing Machines
No water
There's no water entering the machine If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
thanks and please do not forget to accept the solution
Apr 03, 2009 | Tappan MDB531RF Dishwasher
Water not coming into the dishwasher.
Water-inlet valve
Float switch
Water-inlet valve
Float switch
good luck......
Mar 28, 2009 | GE Dishwashers
No water is entering the Exxcel auto option dishwasher
hello there,
1. Water-inlet valve
2. Float switch
Water-inlet valve
Float switch
thanks for using FixYa
Jan 28, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
147 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
