Before you start, be aware that minute traces of static electricity can destroy a hard drive. If possible, wear an
anti-static wrist or foot strap; at the very least, do not work on a carpeted floor, bed, or while wearing static-producing clothing (like fleece). Work on a non-conductive (wood, glass) table grounded to a non-conductive floor (wood, linoleum, tile). Wear latex or anti-static gloves and turn off fans and close windows to avoid dust damage.
1. If you haven't already, back up your data on an external drive.
2. Shut down the computer and unplug the power cord from the computer. Remove the battery.
3. Close the laptop and set it screen-side down on an even surface, with the hinges facing away from you. It should look like this:
4. The component labeled "7" in the above picture is your hard drive. With a small Phillips head screwdriver, carefully remove the screws on this outer casing only. Set them aside and remove the hard drive cover.
5. Your hard drive will be screwed in by one to four screws, depending on assembly.
Gently unscrew these, being careful not to apply too much pressure to the very delicate top and bottom of the drive. Handle by the sides only.
6.There are connecting pins on one side of the hard drive. Identify these and gently pull the hard drive out from this side, not forcing if there's any resistance.
7. Depending on your problem, you may need to remove the silver enclosure to the hard drive. With the appropriate Phillips head screwdriver, unscrew the screws and set them aside, carefully sliding the enclosure off of the hard drive. At this point, your hard drive is extremely susceptible to shock, electric shock, dust, and simple trauma. Be careful.
