Question about Toshiba 35AF44 TV
Toshiba TV volume problem
Toshibe TV, model #35AF44, Serial #21132846Chasis #TAC424, has a problem with the volume turning itself down. The volume bar appears on the TV, the volume goes down and then the volume bar stays on. I have blocked the front of the TV to remove any chance of a stray signal causing the volume to go down. This problem may be due to a surge because I lost a the display on my Surround Sound and 19" TV at the same time. All had surge surge protection.
  • lchick Jan 02, 2009
    I opened the TV up and isolated the problem. There was some stray low voltage coming continously from the "Key B Out". There was a link from "push button and remote board" over to the "front RCA input board" that allowed me to isolate the "Key In", "Key A Out" and the "Key B Out" from the rest of the TV. Now all Remote Control functions have returned and the volume stays where it is left. This was the quick fix but replacement of the board or the small transistor that was leaking would have solved the problem completely but "Hey, who uses the buttons on the TV anymore?"
  • mike19419 Jan 31, 2009
    my DEMO screen will not turn OFF
    seems that the remote is lock
    can not even get into the remote MENU to turn off the   DEMO mode!
    any suggestions
    PS it is driving !@#$%^&  CRAVY  please help
    jan 29/09
  • 1139 Answers
SOURCE: 36a43 volume goes up and down buy itself
This problem sometime occurs due to a bad capacitor in the volume control circuitry. You will need a multimeter and a schematic to find out the proper voltages within the volume control circuitry. I would suggest that if you do not have a background in electronics that you take the set to a qualified shop for repairs.
Thank you,
Posted on Nov 14, 2007
  • 298 Answers
SOURCE: Toshiba (Model : 36A43) - volume goes down automatically
Try removing the batteries from the remote. Then adjust the volume from the tv panel. If the problem is resolved, then it sounds like you may have a stuck remote button.
Posted on Jun 18, 2008
  • 108 Answers
SOURCE: Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Posted on Jan 08, 2009
  • 36 Answers
SOURCE: tv volume turns down by itself
I had that happen to me once and found that one of my remotes was under the sofa cushion, However, I would look at the connections on the pcd that has the volume controls on them, the down switch either has moisture or corrosion behind it, or the switch itself is faulty, if not, remove all dust from inside the set, some may be causing conductivity on the processor, I believe it will be a mechanical type fault rather than electronic...try that...Phil
Posted on May 19, 2009
  • 668 Answers
SOURCE: i was watching tv when suddenly the volume control
The front panel Tactile Switches probably need to be replaced. The part # of the switches is 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this helps,
Posted on Jul 02, 2009
My 40 toshiba model # 42av5000 hd, lcd flat screen, my volume goes down by itself
hi select menu sound setting look for avl if it's on turn it off, if this don't work, you may need to to replace the mainboard, thanks
May 15, 2017 | Toshiba Televison & Video
REPAIR NO SOUND ON toshiba 35af44 tv
If picture is perfect, sound should be there. If not, check its speaker first. If it is found OK, check the audio and system settings. Check and replace the damaged component/s at it audio output section circuit; if all the above said adjustments and checks are OK. If you wish to get some details, check the site linked here. Pull up older posts.
Jan 01, 2014 | Toshiba 35AF44 TV
Toshiba (model 19av500U) volume goes up and down automatically
It may be the remote itself and not the tv, have you tried purchasing an inexpensive universal remote?
Sep 27, 2012 | Toshiba 19AV500U 19-Inch 720p LCD HDTV...
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Dec 27, 2006 | Toshiba CT-90157 Remote Control
Toshiba 35AF44 TV Logo
525 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
