Question about Audiologic Audio Players & Recorders
Audiologic date 12/99 model AH150 ser # 9912007656 3 disc rotary
All of a sudden it will not load the material of the cd's. it rotates but the screen to see what is playing is blank - it will not load them. I cannot find the manual on this.
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
welcomejee
  • 10594 Answers
SOURCE: Rotary table on Sony CDP-CX225 200 disc changer will not rotate
I think CD Mechanism needs service and might required belts replacement.
You need to get service manual of your CDX-C225 model to do this job as manual contains all technical info about mechanism etc.
Posted on Nov 07, 2008
MNfisherman
  • 11896 Answers
SOURCE: Problem with my Onkyo DX-C380
Try cleaning the glass laser eye lens with rubbing alcohol and a cotton swab. If cleaning doesn't work, you may want to change or laser eyee unit.
Posted on Sep 14, 2009
  • 2976 Answers
SOURCE: 5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Posted on Dec 06, 2009
I need a manual for Audiologic clock radio model ACR 1102
Try Googling (audiologic)(ACR 1102)(manual) without parens.
Jul 18, 2017 | Audiologic Audio Players & Recorders
Disc will not load
2 belts wear out on this model. Replace them.
Oct 17, 2014 | Sony CDP-CX400 400-Disc CD Changer
My aiwa cd disc rotating tray is not working i don,t know what's wrong with it
hi there i know wht is problem rotary changer systems like 5 disic or 3 dics chnager.i have 2 oprions for that 1 is,from cd chnager belt small belt between motor another also mechanism like small tears lack white if there not good oily enaugh,maybe stock with tooth,DO u hear motor when u tray chnage disc 1;2;3? if motor burn rotary change then never will work,Some times belts getting older in cd rotary changers.the gey slepery,like flashy,but i hope will help your problem.Regards,Emil
Sep 13, 2012 | Aiwa NSX-DS55 CD Shelf System
The DVD drawer on my Audiologic keeps opening and closing on its own and will not play.
by this i take it you mean when you try to load a dvd this happens. ok the problem is either 1 - a bad run on the tray this fault needs a service tech to repair. fault 2 most common if the laser can not read the disc it will eject it. as a safe mode to not trap the disc. to fix this go to an electronics supply shop and purchase a laser disc cleaner it looks just like a cd/dvd except it has small brushes on it to clean the laser eye on the player run the disc several times
best of luck
merry christmas
Dec 21, 2010 | Audio Players & Recorders
3 Disk Rotary not working
Are you using a disk that the machine can recognise? Some disc players do not recognise certain formats, so it might be worth checking the discs or formats you are using.
Aug 07, 2009 | Philco (R) Capital CD Player
Drill will rotate but will not hammer under load
most of these types of tools have a manual switch it will be located on the body of the drill just behind the chuck on top or bottom or oposit the grip handle. some models have 2 switches.you want to make sure the switch points to the picture that shows a hammer and drill together.also rember it needs to have down pressure for the hammer part to activate.
May 19, 2009 | Dewalt 1 9/16" Rotary Hammer Drill D25551k
Nov 07, 2008 | Sony CDP-CX225 CD Player
Clarion CD Changer in 2003 350Z
hi whats the model number of the changer?
mark
Blue ICE
Feb 21, 2008 | Car Audio & Video
74 people viewed this question
Top Audiologic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Audiologic Audio Player and Recorder Expert? Answer questions, earn points and help others
