Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Paper pulls to right and bunches up when loading
Epson cx 4800 when trying to print thr paper is pulled to the right of printer and bunches up
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 29, 2009
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
EPSON STYLUS CX 7800 HOW DO I ALIGN THE HEADS??
1. Turn on the Epson Stylus CX7800
2. Load several sheets of paper
3. Windows: Right-click the printer icon on you taskbar (in the lower right corner of
your screen). Select Print Head Alignment.
Macintosh OS X: Open the Applications folder and select Epson Printer Utility.
Select your Expson Stylus CX7800 in the printer list, click OK,
and select Print Head Alignment.
Jan 15, 2011 | Epson Office Equipment & Supplies
Does not print
First of all please check the ink level. If it is not finished try followings:
First try to run a cleaning cycle. To do that:
- Load paper in the paper tray. - Access printer utilities. (Right click your printer icon, select printing preferences and click the utility tab to access printer utilities) - Click the nozzle check icon. - Print to check it.
Then click the clean button to clean the print head. - Try it a few times.
İf it doesn't help you can try to run power cleaning cycle. But it uses much ink. There must be enough ink in the cartridge.
Hope this helps.
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
Cx 4800 not printing quality colors
Are you using Epson Genunie Cartridges?
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 22, 2010 | Epson Office Equipment & Supplies
My Epson cx 4200 won't print because each attempt the paper jam light flashes and the printer stops trying to print. The paper is being pulled into the machine un-evenly.
It's highly likely that you either have a foreign object down the paper feed tray or the guides are incorrectly set...
Hopefully one of these will solve this:
1. Remove any paper, tape down the scanner lid and
gently tip your printer upside down and give it a GENTLE shake to see if anything drops out. This is really only something I'd recommend for someone strong and careful so take your time.
2. Check for any jammed foreign objects such as pens, paper clips, etc...that have fallen down into the printer. The place to look is wherever the paper seems to be bunching up most as it goes through
3. Make sure you're inserting the paper, with the guides set to the correct width and not loose. The guides help correct any issues with skew as the paper is pulled in, so this may correct any other issues.
Hope one of these helps..
Jan 24, 2009 | Epson CX4200 All-In-One PSC Printer
Epson 4800 pro
Make sure that the "Encoder Strip" is clean and in the channel for the sensor located on the back side of the printhead carriage.
Jan 06, 2009 | Epson Stylus Pro 4800 InkJet Printer
Paper not loading (but it is)
If it's an older machine, try cleaning the Multi-sensor (next to the printhead with the scissors icon on it).
Mar 12, 2008 | Epson Stylus Pro 4800 InkJet Printer
Epson Stylus CX4600 pulling paper in crooked
Hi, please check if there is a paper jam or any obstruction inside that printer. Check also the platen lever or the left edge guide, make sure that paper is loaded correctly. Try printing again. If issue still present. Your printer needs to be send to service center.
--->>> Tirzo
Oct 12, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Photo paper jam on Stylus 4800
Here are some things to try. Place no more that 15-20 sheets in the printer, ensure they are fully to the right of the carriage and the paper is held securely on the left. You may wish to 'fan' the paper to ensure it will flow freely.
Sep 21, 2007 | Epson Stylus Pro 4800 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
100 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
