Question about LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur...
Regradaire gallery model GLRT218WDS6 freezer cool but refrig not
Unplugged to see if it was the defrost causing the problem but no water in the pan. Freezer makes ice and seems to be fine but the refrigerator only cools for a few days after plugging back in.
  • 3 more comments
  • fisher_craig Dec 31, 2008
    I have already eliminaed the defrost problem by unplugging overnight and had no water in the pan. I have also cleaned the dust from the condensor. It seems to cool for two to three days after plugging back in and than the refrigerator isn't cool enough.
  • fisher_craig Jan 02, 2009
    Sorry I took so long getting back but I've been gone for the holidays. I have unplugged the fridge overnight and had no water in the pan so I don't think it is a problem with defrosting. I have also cleaned the condensor. The fan is working in the freezer. Everything seems to work for a few days after starting it back up after being unplugged but than the fridge part isn't cool enough again. When I press the door switch five times like it says in the book to start or stop the defrost cycle I could hear the condensor come on. The fridge is less than two years old but I don't have the extended warranty.
  • fisher_craig Jan 04, 2009
    The suggestions that I have received so far I have already done before I contacted FixYa so so far I have had no help with this problem. I have already cleaned the condenser and checked to make sure the freezer isn't frosting up. I unplugged it overnight with the doors open and had no water in the pan. It seems to work for a few days after plugging back in but than the fridge part doesn't cool properly. The refrigerator is less than two years old but I didn't get the extended warranty.
  • fisher_craig Jan 05, 2009
    Phil, your solution let me to the problem. Thank you!!
    The solution given to me by Phil let me to the problem and the fridge is working properly now. Thank you!!
    Genius:
  • 1,239 Answers
Hi Do not assume the problem is related to the compressor or the sealed, hermetic system; these types of problems happen only rarely. Your unit may have dirty condenser coils, a door that doesn't seal tightly, or a defective temperature control.
1) Check the cold control. Be sure it is set to "cold." Normally, the temperature inside the refrigerator should be about 37 degrees Fahrenheit.
2) Listen for the freezer fan inside the freezer. When the freezer fan is running, it means the defrost timer and the cold control in the refrigerator are both set to cool.
3) Listen for the compressor fan, where the compressor is located (typically behind or beneath the refrigerator. When the freezer fan is operating, the compressor fan should also be working (most of the time).
4) If one of the fans is not working or the compressor is off, the refrigerator will offer very little cooling or none at all.
Posted on Jan 04, 2009
  • LG Master
  • 19,396 Answers
Even if you had no water in the pan, you still need to test evaporator system parts. Check that the evaporator fan (Regradaire gallery model GLRT218WDS6 freezer cool  - _.gif PS1146336 ) and motor are working, see parts here.
If the Evaporator system is ok, then you need to replace the Defrost thermostat (PS469510).
Also test the wiring harness inside the freezer using a multimeter, a broken contact can also cause the problem.
here is a general diagram, move mouse on picture to locate parts: redarrow.gif Freezer on Top
Here you get all diagrams and parts for your specific model.
    Sergeant:
    Novelist:
  • 326 Answers
Its the problem of the weak compressor thats not working after taking a particular frost load so it works for few days and stops cooling after that.again after resting for a particular period it starts working for a while.check the compressor
  • 242 Answers
Hello , I can try to help , your airflow to the upper fresh food section travels from the freezer up the rear center of the unit to an outlet somewhere on the top or upper back of unit inside , there is a damper/air flap in this supply duct that controls the temp. of the unit , sometimes they will fail or stay closed , if there is no cool air flowing out of the vent on top it is this damper , even if there is some air coming out it may not be opening 100%. Check this and let me know how it goes. Phil
Posted on Dec 31, 2008
  • 3,037 Answers
Hello fisher_craig
You may not be getting airflow, possibly the fan is not blowing the cold air around. I am a little confused on the problem as the title is partly cut off so if you could expand on it, that would be great.
bestdarngood
    Sergeant:
    Champion:
  • 304 Answers
Cooling is poorFor an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
I have a fridgidaire refrige and water keeps pooling in the bottom of the refrige and then leaking out the bottom when it fills.....what is the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
My Refrig is collecting water in the bottom. My freezer is on top and the refrig is on the bottom. Water collects in or under the produce trays. What could be wrong
Without a model number or even a brand, this advise can only be general. You have a blocked defrost drain. Each time the refrigerator does an automatic defrost, the resulting melted frost needs to go down to a drain pain near the compressor, where it will evaporate. If the path to the drain pan is blocked, the water has to go somewhere, in your case, down the inside of the liner of the refrig and to the lowest level, under the produce trays. There may be a tube down the outside of the refrig on back which can be removed for cleaning, or the blockage may only be accessable from the area right by the cooling coils inside the freezer section. (usually located behind the back wall, but sometimes under the freezer section floor) You may find that flushing the drain tube using a turkey baster with warm water will be all that it takes to solve your problem.
Jul 14, 2010 | Refrigerators
Freezer part is okay but refriger part not cold enough
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | Refrigerators
Refrigerator isn't very cold- drinks are just slightly chilled
Usually caused by failure of defrost system, Air ports from freezer to fridge blocked by ice
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | Whirlpool Refrigerators
First thing this a.m. we discovered a puddle of water on the floor on the left side of the fridge. This is not the first time....so we are wondering what is causing this? I am guessing about the profile #...
You have a plugged defrost drain.
Unplug refrig. Unload freezer. Remove shelves. Take back panel out of freezer. Use a turkey baster with hot (not boiling) water to flush water in the area of the defrost drain hole until it is clear and water will run through it into the defrost drain pan under the refrig. The drain is a hole about the size of a nickel, usually in the very back center, below the cooling coils. You can use the turkey baster to force water into and eventually through the drain hole. Remove ice from floor of freezer.
Re-assemble, refill freezer, and plug in. Now, when your refrig defrosts, the water will go out the drain instead of onto the freezer floor and out the freezer door onto your floor.
Aug 05, 2009 | GE Profile PSI23NCR Side by Side...
LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
Dec 04, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Ice acculumates in the bottom of freezer
Defrost drain tube is plugged. Drain is a round hole about the size of a quarter below the evaporator coils. (behind back wall of freezer.) Take a turkey baster with hot (not boiling) water and shoot it into the drain hole until water runs through it (into drain pan under refrig.)
Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Frigidaire Gallery model plhs267za. The refrigator doesn't freeze or emits cold air. When I turne it off for a coule of days it works again. The technician says compressor is ok as weel as fan...
Freezer coil is plugging up with frost, Your problem is defrost timer or heater related. If it is the timer you can located the timer and rotate the Clutch screw for the timer, turn it very slowly Clockwise until you hear one click. The compressor will shut off and the defrost heaters will turn on. Waite about 25-30 minutes and if the refrigerator does not restart (Normal time would be 18-22 minutes) rotate the screw again clockwise small amount and it will start cooling. Observe the drain pan for defrost water. If the refrigerator restarted (18-22 minutes) and no water is in the drain pan you problem is defrost heaters. If after the 25-30 minutes the refrigerator did not restart on its own and water is in the drain pan your problem is the defrost timer.
May 02, 2008 | Refrigerators
LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur... Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
