Question about iRiver H10 MP3 Player
H10 drive problem
On my iriver h10 it was working well untill i accidently places a 40 gig hdd for a desktop near the unit.i think the magnet from the hdd might have done something to the player.i booted up the player and it has most of the songs marked unknown, some songs have the song name partially and the songs that are left don't play at all.the rest of the programs, fm,photo, etc. are ok.i was told by iriver that i need a new drive at 110.00 total.i think thats too much.any suggestions?we tried a re- format from iriver site and it didn't re format sice the drive was updated 5 months ago.
  • 8,596 Answers
Magnet - good theory
Reset, Recovery Tool
if fails, replace
sry
Posted on Jun 26, 2008
SOURCE:
Need help with Iriver srs wow mp3 player
Not promoting Amazon, but here you go...
http://www.amazon.com/s/?ie=UTF8&keywords=iriver+h10+adapter&tag=googhydr-20&index=aps&hvadid=3254940855&ref=pd_sl_6p5by0mgps_b
Jul 25, 2009 | iRiver H10 MP3 Player
Changing hard drive
before you do this take the software off iriver even the hidden (place it onto pc)
make sure the hard drive you wish to place into your h10 is perfect match (it could be more gigs) you just want the size and speed....here you go http://www.youtube.com/watch?v=mKQFEweay1Y
i still have iriver h100 (with a toshiba 40gigs) before the h140 came out
have fun
May 02, 2009 | iRiver H10 MP3 Player
When I start my iriver H10, it is stuck on initializing
hard drive is probably bad -- common problem. cheapest solution is to buy as-is h10 from ebay with a working hard drive (perhaps it has a touchpad problem), open the unit up and replace the drive.
See this forum for info on how to open the player with a torx tool and a plastic pry unit. forum
Plan b - sell unit on ebay in as-is condition and use money toward a top notch 20gb refurb unit for about $30-50 from sellers like metromania
Mar 14, 2009 | iRiver H10 MP3 Player
I need system files for my iRiver H10 20GB MP3 player
hard drive is probably bad -- common problem. cheapest solution is tobuy as-is h10 from ebay with a working hard drive (perhaps it has atouchpad problem), open the unit up and replace the drive.
Planb - sell unit on ebay in as-is condition and use money toward a topnotch 20gb refurb unit for about $30-50 from sellers like metromania
Mar 03, 2009 | iRiver H10 MP3 Player
Restore the system files, connect H10 to recovery tool
The procedure depends on what version you have.
Below there is the procedure for 20 GB , on other models procedure is the same, but you must find the right download for your model.
For 20 GB :
TO RESTORE "SYSTEM FILES MISSING" LOCKED PLAYER
--- This applies ONLY to the 20 gig version of the H10! ---
--- This procedure formats your H10 so all data will be erased on the player! ---
1. Power off H10 - 20gig unit.
2. Insert staple or other small object into reset hole to press reset button.
3. Connect player to USB cable.
3. Hold down Select key (labeled "O" - right button on front of player) while also holding down power key until player boots.
4. Unit must display "Emergency Connection."
5. Unit will now appear as a drive under My Computer. Right click on drive, select Format. No need to change anything, just proceed.
6. Download H10_20GB_System.exe. It is a self-extracting archive. Double click on it and unzip to c:\iriver.
http://www.iriveramerica.com/downloa...0GB_System.exe
7. Locate iriver directory, double click. You will see H10. Double click once again; you will see System.
8. Right click on system, select "Send to" and choose the directory of the player.
from System Files Missing
If you have the 5 or 6 GB see iriver - H10 5/6 GB Series Support
Feb 24, 2009 | iRiver H10 MP3 Player
IRiver H10 Turns On but then Turns Off After 20-50 Minutes
yes by the sounds of it , it is your battery try buying a new battery and see how it works form there if it is still playing up you will have to go to your nearest electronic shop and get them to have a look at it
Oct 10, 2008 | iRiver H10 MP3 Player
Iriver h10 20gb not recognized in UMS
I sometimes have to reset my iRiver in order for my Mac to see it. I have an h10 5gb, to do this, I have to remove the battery then reconnect the battery. Then I connect it the usual way to get into the UMS mode. But I think with yours it has it's own reset button. If it was working and now has stopped, I would think you just need to reset it and try again.
System files missing
I fixed this problem for my mate, here's what I did:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Mike.
Sep 21, 2007 | iRiver H10 MP3 Player
Missing system files
how reinstall the firmware for E10? the laptop doesnt see the HD of E10.
Mar 16, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
