Question about Cameras
Hi there im trying to put my sd card in my camra but the camra is telling me the card is protected how do i resolve this so it works
Is the SD card there should be a little switch to one of the sides, just like floopies in the old times, the switch swiches from write-protection to write-enable
Posted on Dec 31, 2008
When switching on my camra it shows protected card across the screen and wont work
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 03, 2014 | FUJIFILM FinePix AV200 / AV205 Digital...
My camra is saying card locked when i turn the camra on have been through the menu but is does no give any clues to put this rig
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 10, 2014 | HP Photosmart R742 Digital Camera
My camra keeps saying pprotected card and a icon keeps showing up of a camra whats going on?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 08, 2011 | Fuji Photography
Hi, my camera says when im ready to take a pic, that memory card is write protected? how can i get that off my digital camera?
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Dec 14, 2010 | Cameras
I transferred some pictures into a computer recently.and now when i wanted to take some pictures,it wont work.it says there on the screen,"write protect".and all the pictures in it is gone..please help...
Hello
Kind regards
Andrea
Aug 27, 2010 | Olympus EVOLT E-300 Digital Camera
Get message "card locked" - made sure sd card was unlocked, but still got message - tried another sd card and still received message
Hello
Kind regards
Andrea
Apr 21, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Transferred pics from computer to card and the camera will not display them - all are jpeg just like what the camera takes. These were from the camera but I wanted them back on the card also.
once out of the camera & deleted form the card, the camera will not display any of the images because it does not have that function. even jpeg images being the same format cannot be viewed.
Apr 21, 2010 | Kodak EasyShare One Digital Camera
Protected Card
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
Kind regards
Andrea
Jul 11, 2009 | Fuji FinePix A201 Digital Camera
Hi, My memory card will not unlock...I have tried moving the switch on the side and when I re-insert to view my pics it still says "memory card error card locked". Could you please help me with this issue?...
Hello
Kind regards
Andrea
Jan 17, 2009 | Canon PowerShot A560 Digital Camera
Memory card is write protected
thought the cards have a little tab on them so they can be "write protected" it is a little plastic tab on the side of the memory1.gif card you slide up and down. I know most SD cards1.gif have it, CF cards dont so if its anything besides SD memory its probobly the memory card or some little switch or somthing in the camera that tells the camera when the card is in the "Locked" or "Write protected" mode.
Looking at my SD memory cards1.gif they have a little arrow on the edge and they say "Lock" pointing down, the slider is up. Move yours both ways, maybe it has a bad connection in the card (im not sure what it actualy does) or its in a position the camera thinks its locked?
Jan 15, 2008 | Nikon Coolpix 4500 Digital Camera
Cameras Logo
43 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
