Question about Hitachi 43FDX01B TV
Is it my Convergance??
I am not sure my converegecne is off or not. Error: I get a picture and sound but the colors are out line by 4" or so. On the bottom of the screen green shadows occur and on the top red shadows. The channel indicator is tilted at an angle (green) however the stereo indicator is fine (red). I checked the main convergence (was ok) and even looked at the "secret" grid but was not able to tell if anythign was off on the grid. It appeared to be OK. Is there anythign else that would cause the color to be distorted like that? I think the bulbs look good since all three colors are present, not in the right place but they are there. Any ideas? Is there a guide for the special convergence menu that woudl help me allign the colors better? Could that be the case? Any help woudl be appreciated before I spend $400 on a service call. The TV is only 3 1/2 years old. HELP??
  • 398 Answers
Do not try to align the colors with the remote. One of your convergence IC's has gone bad and needs to be replaced, possible burning one of the 3 low value resistors next to it. If you change the convergence settings now then they will have to be reset when the new IC is installed.
Posted on Jun 26, 2007
The colors is making the image 3d with colors red , blue
Hi, This sound like a common problems in a little older " rear projection " flat panel t.v.'s-it is simply a matter to go into menu then under picture, select either convergance or Multi point convergance and adjust away. I think this will help, Good luck, Prodzilla
Apr 11, 2011 | Televison & Video
A curve of red blue yellow lines at the top of screen and when dish is off it has these colors in a square around the screeen. When dish is on almost look like a double picture. Was fine one second and...
hello it sound like convergance problem go in to the menu on your tv and try resetting the convergance. if don't reset then the convergance ic need to be replaced hope it helps
regards
shaun
Feb 25, 2011 | RCA R52WM24 52" HDTV Projection Television
Toshiba 51h84 "Crooked Picture"
Still the convergece prob.The FL231 fuse near the FBT transformer it dead.The square fuses 3 rectangles fuses.One in the middle.
Aug 09, 2009 | Toshiba 51H84 51" Rear Projection...
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
Poblems with colors lining up
Look in the menus for the convergance adjustments. It sounds like red is out of adjustment.
Jun 12, 2008 | Sony KP-57WV600 57" Rear Projection...
Two green lines on bottom left corner
Sounds like a convergance issue. I would have a tech set the convergance for you if you have not done it before, it can be tricky and you could make worse.
May 11, 2008 | Toshiba 65HM167 65" Projection Television
sounds like convergance iC bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 17, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Picture & Color Distorted
Convergance IC replace.
Dec 11, 2007 | Toshiba 50HX70 50" Rear Projection...
Hitachi 43FDX01B TV Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
