Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
Loose oven door handle on kitchenaid gas range
The model is kgrt607. There is no obvious way to get to the screws that hold the handle in place. Does anyone know how to take the door apart to get to the screws to replace and tighten them?
I just did this in about 15 minutes.
Open the door 1/4 of the way and yank forward. The hinge slide right out.
Flip the door upside down. There are screws on the bottom that release the front panel. this reveals a couple more screws that hold on the the top front panel.
Once you get that off you can attach the handle and put it all back together.
Posted on Jan 04, 2010
    Sergeant:
  • 311 Answers
Youl have to take apart the door.the screws are on the other side of the glass/framing
Posted on Jan 01, 2009
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
Can you please tell me how to remove the oven door?
If you are trying to clean between the inner (heat shield) glass and the outer glass (safety glass for looks), you may not have to remove the whole door. On most models, the outer glass is either integral to the handle and frame or at least is trapped by the handle and frame. Open the door and look inside. There should be either two or four screws right at the top that hold the handle and frame assembly in place. You may find that when you take these off, the handle slides off, and the glass can either slide up or the whole frame will rock outward. Be VERY careful, this is safety glass and shatters into 2mmx4mm pieces easily if you bump it.
If the whole door has to come off, most new models don't even need screws taken out... you just pry up the two metal tabs next to the hinges, and it unlocks and you slide the door up off the hinges. See the link for instructions if you need to remove the door and take it apart. This covers most oven doors.
Cleaning between the glass of an oven door Frigidaire Jim Carson
Jan 02, 2016 | Ovens
How can I fix the loose handle of the oven door ?
Open the door and lock it down, or remove it from the oven. Remove the screws holding the inner panel to the door. Remove inner panel, then remove the screws holding in the handle. Reverse to re-install.
Feb 15, 2015 | Ovens
Any one know an easier way to dismantle the hinge circled in the image as the external door handle spring has tripped and I want to put it back. Help anyone! !!!
I HAD THAT HAPPEN TO ME ON MY OVEN & IT WAS A REAL PAIN TO GET IT BACK ON. I HAD TO USE A LONG SCREW DRIVER TO HOLD THE LATCH WHILE I LINED UP THE DOOR TO PUT BACK ON. LOOKS LIKE FROM THE PICTURE THAT THERE IS A BOLT THAT YOU CAN TAKE OFF THE LATCH, THEN PUT THE OVEN DOOR INTO PLACE THEN PUT THE BOLT BACK ON. IT MAY TAKE 2 PEOPLE TO DO THIS.
Feb 01, 2015 | Ovens
HOw do I refit the handle on a hotpoint SY36w oven door please?
Most oven doors handles are held in by screws from the inside of the door. Inside the front side of the door, so you need to remove the inside of the door to get at them. You should be able to remove the door from the oven or at least lock it in the down position. Carefully remove the screws and pay attention to which screws goes where. Then remove the back, tighten the screws holding the handle in and replace the back Document or take pictures/video of what you do to make sure everything goes back where it should. Ba careful with the glass.
Jan 21, 2015 | Hotpoint Ovens
Removing glass from whirlpool oven door
I've removed all the screws that I can see. Looks like the brackets that hold on the handle are keeping the whole thing from coming apart, but the brackets are behind the glass and the screws enter from the inside meaning that I will have to remove the glass to be able to remove the handle.
Resource: http://b2b.lovemyhome.net/
Nov 06, 2012 | Ovens
WHILE MAKING HOT CHOCOLATE THE OTHER DAY, THE MILK BOILED OVER AND SOME OF THE MILK WENT THREW THE SLITS AT THE TOP OF THE OVEN DOOR BETWEEN THE TWO GLASSES IN THE DOOR. IS THERE ANY WAY TO OPEN UP THE...
First, you will need a heavy blanket to place the door on once you have removed it from the oven. Open the door slightly, until it stays open by itself, about 15 degrees. Lift the oven door off of the hinges and place on the heavy blanket. (The hinges may snap shut when you pull the door up and off, but this is actually normal. It takes a bit of finesse to get the door back on the hinges if they will not stay out.)
Remove the 4 screws across the bottom of the door. Next, stand the door up with the bottom on the blanket and the front facing you.(Hold the door by gripping firmly around the middle edges to maneuver door)
Now, while holding the handle, remove the 2 screws that hold the handle on, unscrewing them just enough until the handle is free. (You do not want the spacers dropping off the screws) Hold the door together with one hand while placing the handle out of your way.
Once again, grab the door firmly by the middle outer edges and lie the door down, the inside facing down. You should be able to lift up the outer panel and glass and clean the inside of the outer glass.
Reverse the above procedure to reassembly the door. You can also take the door apart further if you have stains inside the other glasses. Here is a link to a schematic for your oven door.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0211500-00004.png
Apr 15, 2011 | Kenmore Ovens
Door Handle coming loose
Hello,it would depend on the brand of appliance,its model number and how it was designed.In many cases the door may have to disassembled to access screws or nuts holding the handle ends.If the end caps which the screws or nut fasten to are stripped,the handle may need to be replaced.
Thanks
May 27, 2010 | Ovens
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
387 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
