HP LaserJet 2820 Printer Logo
Posted on Dec 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer display shows I am low on something. The icon it is low on is on the right hand side of the toner colors. I don't know what the item is called so I don't know what to order.
Anonymous
Level 3:
Genius:
  • Master 1,913 Answers
  • Posted on Dec 31, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1913
Questions
5
Helped
687645
Points
5322
It is tonet or u can also say "ink cartridge" change it or shaked it.then refix it.open the front dooeu see ink cartridge then pull it.
I think i have a fuser error. When I print something the right side of the paper is very light in color. If I print multiple pages, it gets lighter by every page.
Put paper in the manual feed tray. Print. When the page gets half way into the printer, open the cover. Remove the toner. Look down at the paper. Is the right side lighter than the left? If yes, replace the toner cartridge. I don't believe that a fuser could cause your problem.
1helpful
MFC-7840W Printer Brother, we have replaced the toner many times and the printer always shows the message on its screen: low toner, and after that shows: toner life end, what we can do, because this is the...
Open the front cover. Remove the drum and toner. Remove the toner from the drum by pressing and holding the green/blue tab on the right side then lift the toner out. Shake the toner side to side for 6 times, and on the drum unit slide the blue/green tab on the far left side from left to right for 6 times also. reinstall the toner back to the drum unit. reinstall drum and toner back to the machine. Close the front cover. The display should show the date and time.
Hope this will help.
It only prints on the left side of the paper. The print fades and then there is nothing on the right hand side. It doesn't matter what you print or from what program, only about 2" prints down the...
1. Take the toner out and shake it side to side so you even the toner level in the cartridge.
2. If this won't fix it, check toner level, might be low. If low, you need to replace toner.
3. Last option, you might have to replace the Photoconductor Unit.
How do I know which toner cartridge needs replacing?
The printer will alert you when the cartridge is running low on the display of the unit itself and also on your computer screen in the lower right hand side corner with an error display. Each place will identify the cartridge that is running low until the level is too small to print. Then printing stops until the cartridge is changed.
I havean HP 2600n, anything red prints in a faded yellow. I've seen other posting regarding this put all answers suggest something wrong with the printer. However, when I had a supplies status page...
change the cartridges. Theres nothing else that can alter the color like that without rewriting the drivers. B4 you do, take each one out, shake gently from side to side to even out any toner, and try again.If they print better, your toner is low.
1helpful
2answers
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Toner Low And it is not printing
Have you changed the affected toner? Most printers will stop printing when one toner is showing empty.
Hp color laserjet 2820. Low on something. Icon next to toner colo
If you are talking about the icons under the little display first four are the toners the one on the far right is the drum unit it has a small solid circle with a large bar going through it rounded at the bottom & has like a fish tail on the top goes top left to bottom right.
9helpful
3answers
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
1helpful
Toner low, tone life end
There is a gear on the left hand side of the toner to reset the toner count this can cheated be rewinding it. Yes the design is to stop the refillers or at least slow them down a bit. If this fails purchase a new genuine toner but I have seen problems with the switch that resets the toner (Either the spring on the switch has popped off or the main board has failed).
k24674
Grand Canyon Tech
Grand Canyon Tech
