Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Need to reset the number of rings before fax pickup on 2 hp offi
Office jets:
1) Officejet Pro L7780 all in one
2) 7310 all in one
  • Anonymous Jan 13, 2009
    I want to increase the number of rings before the fax will pick up
    Larry
    Genius:
  • 1,605 Answers
Default ring is 5.
if need to change the ring, then you will be in maual answer mode.
better choice is to change the ring on the phone and the answer machine.
Posted on Jan 13, 2009
We have the HP office jet pro 7780 I have a new phone number and need help programing a new number in the fax machine to receive fax
1 Click the Set-up button 2 Go to Fax Settings/Fax Set-Up/Basic Fax Set-up (Whatever you get to see first) 3 On Fax Header, press okay 4 And then just enter your name, hit ok 5 And then it will be asking you to enter your Fax NUMBER 6 HIT OKAY again.
I hope this helped.
Feb 08, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
I have a HP Office Jet 6500. Can you tell me how to fax more than one page from the glass without redialing. After my first page is sent, can a prompt be set up asking if I have another page?
Put the documents you want to fax in the tray.Dial the fax number.After that the printer will scan the docs first and the send via memory.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 17, 2010 | HP Officejet Pro L7380 Laser Printer
I need a test fax to see if i can receive on my hp office jet pro 8500.
Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
When your fax is received by the HP Test Fax Service, It will generate a return fax to you within five minutes confirming that we received your fax. This verifies that you can both send and receive a fax with your fax machine.
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Having issues receving Fax on a shared phone line with voicemail . Will only recevie when left on auto or by pressing the manual button . HP Officejet Pro 8500 A909g Series
THE VOICEMAIL WILL KICK-IN AFTER A CERTAIN NUMBER OF RINGS WHEN NO-ONE ANSWERS. FOR THE FAX MACHINE TO ANSWER PROPERLY IT WILL HAVE TO BE SET TO A LESSER NUMBER OF RINGS....POSSIBLY 2 RINGS LESS TO ENSURE THERE IS NO PICKUP- ANSWER INTERFERENCE FROM THE VOICE-Mail.
Jun 07, 2010 | HP Office Equipment & Supplies
I want to know how to recieve the fax conformation hp office jet pro l7590
Hi va707ejo,
Press Setup and select Print report.Then select fax confirmation and choose the option which yiu would like..
Thank U
Jan 13, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Faxes office Jet K60
You have to have either a dedicated phone line just for the fax --or-- pay your phone company approximately $2 a month for a service called Distinctive Ringtone. This service will ring a certain way when you have an incoming fax. You will then configure your fax machine to pick up when this distinctive rington is heard. The ringtone is usually two or three quick rings. Your fax machine's settings will have this setting.
Unfortunately, you can't just plug your fax machine into your phone line and start sending/receiving faxes. Look through your fax machine's manual regarding the distinctive ring service. Good luck!!
Oct 01, 2008 | HP OfficeJet k60 All-In-One InkJet Printer
Hp Office Jet 4315 cancell a fax number?
go to the fax number, then try pressing the X button. Other wise if u are ready to loose all numbers, just reset the machine
Jan 08, 2008 | HP Officejet 4215 All-in-One Color Photo...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
149 people viewed this question
Ben Johnson
