Question about Curtis-Mathis CM32010 TV
Curtis Mathes CM32010 has no sound
Just about two weeks ago my TV just decided to stop playing any sound. All DVD players and VCR's will not play any sound when connected to the back or front panel jacks. All these devices will play audio when connected to a secondary source, so I know they work. The picture is fine, but I just cant get any audio and when I change the channels with the remote, it will take a few seconds to respond to the change. Other than these problems the set works fine. I have opened up the tv and checked to make sure that any of the buttons are not stuck from the inside, but still have the problem. Any help or advice is greatly appreciated. Thanks in advance.
  • nanipoo Dec 23, 2007
    JUST TWO WEEKS AGO I MUTED MY TV BECAUSE I WAS ON THE PHONE AND WHEN I WAS DONE I TRIED TO UNMUTE IT THE VOLUME WOULDN'T COME ON. FOR SOME REASON THE VOLUME DOESN'T WORK AT ALL. BUT THE PICTURE IS FINE AND I STILL HAVE ALL THE CHANNELS BUT NO SOUND AT ALL.
  • Curtis-Mathis Master
  • 3,828 Answers
Any user manual online ?
unplug from wall
see if remote will get you to system settings audio
Posted on Apr 06, 2017
3 Suggested Answers
SOURCE:
  • 133 Answers
SOURCE: Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Posted on Jul 06, 2008
mghall69
  • 12 Answers
SOURCE: need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
Posted on May 09, 2009
I hooked my jvc dvd player to my curtismathes tv movies only show in black and white why
Try contacting the folks at the link below:
http://www.curtis-mathes.com
They probably have a member on their site that can help you with the problem you are having with your JVC DVD player only showing in back in white on your Curtis Mathes television. They love helping folks and they do it for free :)
Dec 10, 2013 | Curtis-Mathis CM27101S TV
Hooking up older Curtis-Mathes TV to a newer DVD player.
It is hopeless if the television will not stop cycling through its channels. That is an unattended operation and may point to there being something really wrong with this television OR it may be one of the televisions that has to be fed a signal of some type in order to stop cycling through its channels.
First, how would you connect a dvd player to this television: You would have to buy a part that has yellow red and white holes on one side and a coax output on the other side. I bought one from my local drugstore a little while back. It is Philips brand, and it says connect any dvd player to any television right on the package. I don't know if they are sold anymore, but I imagine that some store would still have them. Then you would disconnect the vcr and connect that part there with the dvd player connected to it (the part I described).
Next, if your television is the sort that needs at least one channel to be programmed into it so it won't keep cycling them, you would have to connect a converter box where you have the vcr connected right now. I know, this troubleshooting takes work, and there is no way to tell if this will work.
Dec 02, 2012 | Televison & Video
Code fro lcd2425a curtis mathes television
Hi
Setup code for Curits Mathes Tv with RCA RCR 311B unversal remote control is,
1078
OK.
Jul 14, 2011 | Curtis-Mathis CM32010 TV
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
I am trying to program channel 73 into my curtis mathis tv. Why won't it program to any channel over 69?
because this tv has no hyperband tuner (also called sometimes s-band or superband tuner 70-99).
but if you have an old vcr with a good tuner built in u can watch these channels over it (even a broken one which dont play anymore would do it still :))
regards
Feb 20, 2011 | Curtis-Mathis CM32010 TV
How do u hook up vcr to the curtis tv and what is a good phone number for the curtis repair
U have a RCA AV component cable R,Y,W just hook that up for the out for the VCR-out put holes and the other end of the cable R,Y,W just hook it up TV-in input holes.That it,now put TV in Video 1 or 2 and play the VCR- VHS tape.Look in ur Phone book Yellow pages.Tv repair,any tv shops can do the CRT-tv analog tv repair.
Jan 21, 2011 | Curtis-Mathis CM32010 TV
Problem with dvd player in combo curtis dvd vcr
try to clean the lens with a cd/dvd cleaner available at your local stores. just insert the cleaning disk and wait until it's done. hope this helps!
Oct 15, 2008 | Curtis DVD-7600 DVD Player/VCR
Jul 03, 2008 | Curtis-Mathis CM32010 TV
Curtis-Mathis CM32010 TV Logo
134 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Nick Novikov
Nick Novikov
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
