Question about Intel D845GVSR Motherboard
Memory Bank 1 Not Installed
Hello:
I have an Intel D845EPI motherboard with only 256 MB on it. I want to add another 256 to the other memory slot but that slot isn't picking up in the BIOS. Its just greyed out with no options to enable it. I've upgraded the BIOS to VA84510A.86A.0056.A20. Is there anything else I can do? Jumper setting?
Thanks.
-Steve
  • Buddy16 Jan 02, 2009
    Thanks to everyone for their input. I put in two sticks of 256 MB of the same speed. It tested good. I should have known that on my own.
    -Steve
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    Hi, jumper setting is used for harddisk only. What type of your other 256mb memory card? because if you want to upgrade memory cards, their types should be the same. ex. Like if your using PC-667 256mb memory, the other memory card should also be PC-667. So are the types of your memory cards the same?
    *Drop me a comment so i can assist you.
    Champion:
  • 254 Answers
Remove the cmos battery for about and hour make sure that the power is unplugged from the pc then reset your bios options
if that fails , use the new ram by itself first if all ok
then use the old ram in the second slot..
hope this helps
Posted on Jan 01, 2009
Whats max RDRAM I can install on A49507-903 ?
2GB.
The Intel Desktop Board D850GB has four RIMM sockets (two sockets for each channel) and supports the following memory features:
Single- or double-sided RIMM configurations
Maximum of 32 Direct Rambus devices per channel
Total system memory configurations from 128 MB (minimum) to 2 GB (maximum) utilizing 128/144 Mbit or 256/288 Mbit technology PC600 or PC800 compliant RDRAM
Serial Presence Detect (SPD) based configuration for optimal memory operation
Suspend to RAM support
ECC and non-ECC support
When installing memory, note the following:
The four RIMM sockets are grouped into two banks:
Bank 0 (labeled on the board as RIMM1 and RIMM2)
Bank 1 (labeled on the board as RIMM3 and RIMM4)
Bank 0 must be populated first ensuring that the RDRAM installed in RIMM1 and RIMM2 is identical in speed, size, and density. For example, the minimum system configuration would use two 64 MB RIMM modules of PC600 or PC800 RDRAM.
If the desired memory configuration has been achieved by populating Bank 0, then Bank 1 should be filled with two Continuity RIMMs.
If memory is to be installed in Bank 1, the RIMM modules installed in RIMM3 and RIMM4 must be identical in size and density to each other, and match the speed of the RIMM modules in Bank 0. The RIMM modules do not, however, need to match those in Bank 0 in size and density. For example, if Bank 0 has two 128 MB RIMMs of PC800 RDRAM, Bank 1 would require PC800 RDRAM also, however, any other supported RIMM modules such as 64 MB or 192 MB could be used.
If ECC functionality is required, all installed RIMM modules must be ECC-compliant.
Jun 08, 2012 | Computers & Internet
Will 9500 GT either 512 mb or 1 gb work on intel la crosse D865GLC board..?? it has 3 pci slots 32-bit long..
Yes you can.
For 512 Mb RAM you can use a single 512 Mb memory module or two 256 Mb memory modules.
For 1 Gb RAM you can use a single 1 Gb memory module or two 512 Mb memory modules.
Apr 13, 2011 | Intel Desktop Board D865GLC (MBIND865GLC)...
Ram support for intel 845 motherboard
Hello. this website will show you the supported RAM for your Motherboard.
RAM Support
Hope this helps!
Apr 11, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I am having Intel Board SE7501BR2, i wanted to know how much RAM does it support and of what speed, because currently it is having 512 mb ram with speed of DDR$266 mhz.
This motherboard can support up to 2Gb of DDR266 RAM modules.
Attached is part of the memory detail from the manual.
If you need a copy of the manual. please click on this link to download :-
ftp://serwery.optimus.pl/Servers/Motherboards/SE7501BR2/Dokumenty/se7501br2tps.pdf
3.1.2.2 Memory Configuration
Memory interface between the MCH and DIMMs is 144 bits wide. This requires that two DIMMs
be populated per bank in order for the system to operate. At least one bank has to be populated
in order for the system to boot. If additional banks have less than two DIMMs, the memory for
that bank(s) will not be available to the system.
There are two banks of DIMMs, labeled Bank1 and Bank2. Bank1 contains DIMM locations
DIMM1A and DIMM1B and Bank2 contains DIMM2A and DIMM2B. DIMM socket identifiers are
marked with silk screen next to each DIMM socket on the baseboard. The sockets associated
with any given bank are located next to each other.
The baseboard's signal integrity is optimized when memory banks are populated in order.
Therefore, DIMM Bank1 must be populated before Bank2.
DIMM and memory configurations must adhere to the following:
• DDR266 DDR registered DIMM modules
• DIMM organization: x72 ECC
• Pin count: 184
• DIMM capacity: 128 MB, 256 MB, 512 MB, 1 GB, 2 GB
• Serial PD: JEDEC Rev 2.0
• Voltage options: 2.5 V (VDD/VDDQ)
• Interface: SSTL2
• Two DIMMs must be populated in a bank for a 144-bit wide memory data path
• One or two memory banks may be populated
Table 2. Memory Bank Labels
Memory DIMM Bank Row
J8D22 (DIMM 1A), J8D15 (DIMM 1B) 1 0, 1
J8D7 (DIMM 2A), J8D1 (DIMM 2B) 2 2, 3
Note: Memory must be installed in pairs; DIMM Bank1 must be populated before DIMM Bank2.
Memory within a DIMM bank must be identical; between banks only the DIMM size may be
different.
Functional Architecture Intel® Server Board SE7501BR2 Technical Product Specification
26 Revision 1.2
Intel Order Number C13977-003
Figure 3. Memory Bank Label Definition
Sep 25, 2010 | Intel Server Board SE7501BR2 Motherboard
My desktop has intel 845gvsr board, n have a 256 mb ram installed on it. i want to upgrade it to 1gb what kind of ram should i go for
Each memory slot can hold DDR PC2700 or DDR PC3200 Non-ECC, Non-buffered RAM with a maximum of 1GB per slot.
You can refer to this site for more info on your RAM and motherboard.
http://www.crucial.com/store/listparts.aspx?model=D845GVSR
Thanks for using Fixya.
Feb 23, 2010 | Intel D845GVSR Motherboard
Memory limit for my dell E139761 motherboard
Although the motherboard ultimately decides how much memory your system can handle, Dell does not list the specifications of motherboards. You need the model number of the computer, and if the motherboard is not the original one that came in the computer when it was built by Dell they won't know either.
You can go to dell.com and put in your service tag to see the specifications yourself. If you post the computer model number or service tag here that's what someone else will do anyway.
Mar 23, 2009 | Dell Computers & Internet
E machine T1150 wont start up
Make sure you have the memory installed correctly. Those beep codes identify it as bad memory. Try the old RAM.
Good luck with this.
Mar 19, 2009 | E-Machines T6420 PC Desktop
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
Intel D845GVSR Motherboard Logo
627 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
