Question about Sharp R-1480 Microwave Oven
Sharp carousel non functional overhead light
New light bulbs,,,,,lights won't work....
sharp overhead microwave r series microwave
  • Sharp Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 01, 2009
What light bulbs are for a Sharp R-1502 carousel microwave?
Hi,I would try (www.espares.co.uk),you can put the model in and it should give you the right lamp for your microwave,all the best.
Feb 05, 2018 | GE Microwave Ovens
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
How do I replace the light bulb on my Sharp Carousel microwave - model R-8R51
Strip the microwave and you will see the bulb holder at the back you can use yo hand to turn itsideways
Sep 15, 2014 | Microwave Ovens
How do I find a replacement light for my sharp r-320fw microwave
Sharp Carousel Microwave / Light bulb replacement: http://youtu.be/36RE1bG0aVk
Check out this video, it may help you. Looks like they're a common bulb.
Sep 03, 2014 | Sharp Microwave Ovens
Microwave heats, but the turntable and lights don't work
see the chart for light 1)
  • Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • 2) the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
    God bless you
    Sep 30, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
    Re: Sharp carousel microwave oven minute display light out
    Hello there
    To replace the light you will first have to remove the outer shell.
    To do this
    (1). Remove all of the screws on the back of the microwave that hold on the shell
    (2) Remove the screws that are on the bottom.
    (3) now the shell should slide off towards the back of the microvave.
    Note : this may take a little bit of pressure to get it off ok?
    (4) Once the cover is off look towards the fromt of the microwave and
    you will see the bulb. now just replace the bulb and reinsert the cover and the screws and you are all done ok? pretty easy ha/
    best regards michael
    Sep 28, 2009 | Sharp Microwave Ovens
    Microwave touch pad work light doesn't work
    We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
    Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Dec 29, 2007 | Microwave Ovens
    Sharp Carousel Microwave R-1601 - Need to Replace Door
    We have the service manual for the R1750-series ovens available at our Web site.
    It's not exactly the same, but it should be generally close enough to help you.
    It's at http://microwavedisplay.com/r1750_r1751_...
    Most door panels separate like the one in the example photo below.
    Please write back with more details if you need further help.
    Dec 01, 2007 | Sharp R-1480 Microwave Oven
    Where is the light bulb in an old Sharp Carousel Microwave?
    Microwave_svc's site is awesome! I was able to get all the help I needed for a similar Sharp Carousel microwave. My bulb was simply loose in the socket base causing intermittent bulb lighting. Microwave_svc's helpful links got me to the service manual and, along with a nice set of "tamper-proof" screw compatible TORX bits I bought at HarborFreight, I was easily able to get cover off, remove bulb socket, tighten bulb, re-install bulb socket, button unit back up, and, voila, the light now works without intermittent blinking. FIXYA!!!!
    Many thanks to guru microwave_svc!!!!!!!
    Nov 21, 2007 | Sharp R-510HW Microwave Oven
    Sharp R-1480 Microwave Oven Logo
    157 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
