Question about Frigidaire FEF336BC Electric Kitchen Range
Oven door lock engaged while NOT in cleaning mode with door open. Will not disengage. Cycled main power, cancel button does not work; Oven also inoperable. HELP! Appreciate any tips or tricks to get it unlocked. Thanks.
  • 11 more comments
  • Anonymous Nov 30, 2007
    Law student... finals start in 3 days... fridgidaire oven lock is stuck with the door open. the light is on and the oven is beeping every 3 minutes. not what i need right now. Have hit about every button and held it down. unplugged it for a few minutes...
  • Anonymous Dec 25, 2007
    my oven door wont unlock
  • AGC2044 Jan 08, 2008
    Self-Cleaning Oven - Frigidaire: No manual. Started Self-Clean process, door locked and have no idea how to unlock it now.
  • help_my_oven Feb 14, 2008
    My oven was off and closed and I leaned on the control panel and now it is locked and beeps every few minutes.   Door opens and closes, but makes wierd sound when open.  Will not unlock and will not work?
  • Len 59 Mar 24, 2008
    I have a Frigidaire electric stove. Modl MEF352CGSD. I have had it for about 10 years. Today after cooking Easter dinner the door lock was engaged, dr is displayed and I can not get the lock to disengage so the oven will close completely. Please help.
    Thanks,
    Linda
  • Anonymous May 26, 2008
    Oven door lock will not disengage
  • JJones072 Jun 25, 2008
    My frigidaire over keeps beeping after I attempted to self clean and an error message of F90 appeared. Door lock keeps going forever. It will unlock however then relock and start beeping all over again. I've unplugged overnight and still the F90 reappears. I just wanted to clean the oven and the self cleaning function never started. Please Help! Thanks
  • winkster432 Jul 01, 2008
    Oven door locked, unable to use oven/burners....did not press clean button...
  • johnkittredg Jul 28, 2008
    lock is on and wont go off by holding the button, any other solutions?
  • christinaswi Sep 04, 2008
    i dont know what the model of my oven is, but it is locked because it says it is "cleaning" i pressed canel and it does not unlock it. it has already been almost 9 hours and i dont know what to do...HELP!!!!!
    christina
  • lrp1225 Sep 10, 2008
    I think I have a problem which was mentioned---somehow, I started "clean", while the door was open---now the latch will not let the door close--and I have no functions---
    please clearly explain a simple fix--thanks
  • Anonymous Nov 22, 2008
    have tried unplugging, wont reset. have tried tech 17 fix, doesnt work. any other ideas?
  • bigred5 Dec 28, 2008
    My door says locked but is unlocked
    I tried holding clear button in, unplugging, holding door lock in and holding clear at same time (then it said F1 error whatever that is)
    Any advice
Hold the lock button for 3-5 seconds...
Posted on Apr 03, 2008
In our case the door was open but the lock was latched. Holding the Clear/Off button had no effect. We unplugged the unit. Then while one person held the oven door light switch button in, another person plugged the unit in. While still holding the light switch button in, the Clear/Off button was pressed for 10-15 seconds, at which point "locked" appeared in the display. Then, while still holding the light switch button in, pressing and holding the Clear/Off button unlocked the unit and everything worked!
Posted on Dec 26, 2009
  • mis_genious Dec 26, 2009
  • 36 Answers
Push and hold in on the door switch with the door open and push cancel will reset
Posted on Dec 29, 2007
My door locked after a power failure. There is not anything published by the manufacture to solve problem. I pressed clear off key till clock apeared, then presed clock, as thou I was going to set the time. Clock is now flashing, pressed clock again and door opened.
Posted on May 14, 2009
My range door is open and in the locked position. How can I close it? To close an open door when it’s in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  1. Program the oven to self-clean.
  2. Wait 20 seconds.
  3. Cancel self-clean.
  4. Wait 20 seconds.
Posted on Jan 17, 2010
OK the April 12 solution worked for me. I held the door button in and pressed the broil button for about 5-10 seconds. The lock moved and I was able to close the door. Thank you!!!!!!!
Posted on May 09, 2009
My oven door remained locked after the cleaning cycle- model # FES365ESA. I flipped the breaker and then turned the oven on just to 350. Then, I held the Clear/Off button until the door opened. Don't know why it worked, but it did. Hope this helps anyone else. There seems to be no mention of it in the owner's manual either.
Posted on Apr 10, 2008
Hold in the door button and push broil until the latch makes a 360 degree
then the door lock should stop flashing and the oven will work again
Posted on Apr 12, 2008
  • 3 more comments
  • banana72 Dec 22, 2010
    This worked great...let me clarify...the door button is not on control panel..it is on the top left when you open the oven door..just push button and broil button, you will see the lever move back to original position...Who ever you are..you saved Christmas. :).
  • drshomes Jan 01, 2011
    Thank you sooooo much! New Years day will be filled with fun AND food!!! Happy New Year!
  • mr-ganja Apr 04, 2011
    You ROCK!!! I was about to make my girlfriend cook the pizza in the microwave! hehe
  • Mali Oct 13, 2011
    Thank You, I was getting so hungry for something cooked in the oven. :) It worked.
  • Lee Niven Oct 30, 2011
    It worked. Not sure what the 360 degree biz is, but the latch moved back to the unlocked position when I held the door open and pushed the broil button. Thanks all!!
  • 248 Answers
  Try unplugging unit for a minute.
Posted on Oct 13, 2007
Followed suggestion to unplug unit. When plugged in pushed and held clear/off button for @5 seconds. Unit cleared, what a relief.
Posted on Jul 11, 2010
  • george272 Nov 23, 2010
    We had a problem where the bottom oven was locked and the cleaning fans were blowing..
    Nothing worked so my wife banged on it and it unlocked :-)
    I hate this oven.
Here's what worked for us when the oven door wouldn't unlock. Hold the LOCK button down until the display shows "LOCKED" with a little padlock icon. Then select the OFF button. Yaaaay... dinner is only an hour late!
Open SezMe!
We are geniuses!
Posted on Apr 28, 2010
Had exact same problem with oven door locked in open position while trying to clean....thanks tech17! Your solution worked great!
Posted on Jan 18, 2008
Guest answer that wrote on 4.12.08 fixed my problem. My oven door was open whern I started the clean cycle. I did as was suggested and the lock moved to the other side allowing me to be able to close the oven door.
Posted on Dec 31, 2008
My locking pin was slightly bent in a manner that would not let the door fully shut.  I bent it so that it would line up with the door hole.
Posted on Jun 03, 2008
Thank you very much. your suggestion worked very well.
Posted on Apr 27, 2008
Service man said we need new electronic overlay and oven probe--$250 plus !1
Tech 17 solution confusing- where is "cancel" button?
"hold" in light switch?
Help us who are not so sharp.
Unplugging did not help.
Posted on Jan 23, 2008
I just did this, Hold the clear button until it beeps. When you get it open and shut it hold the clear again, close it and in a few seconds the door unlocks by itself.
Posted on Jun 23, 2012
To unlock the safty lock when door is stuck open.....push and hold the button just inside the oven door and, while holding that in, push and hold the clear button for 3 seconds
Posted on Feb 13, 2011
Door was open and lock was engaged. I held the door button in for about 5 to 10 seconds. The lock cycled, door closed, and lock light went off. Whew!
Posted on Oct 03, 2010
OK, here's what I did. My company leaned against the door and LOCKED it. No freaking manual thanks to the previous owner. SOOO, I held down the Clear key until the little red lock went away. Then I held down the Clear key again until the "Door Locked" display went off. YAY, success!!! Hope that helps!
Posted on Aug 15, 2010
Worked perfectly!
Posted on Apr 14, 2008
3 Suggested Answers
SOURCE:
  • 1214 Answers
SOURCE: How do I unlock the oven door?
If the lock is engaged, is the oven in a self cleaning cycle? If so, cycle power to the oven, that should cancel the self cleaning cycle.
Reply back if that worked or not and I'll try to help you further.
Posted on Jan 24, 2009
  • 302 Answers
SOURCE: Oven door lock engaged while NOT in cleaning mode with door open
The question isn't that clear as to what your problem is but try unplugging the stove or turning the power off to the stove at your main fuse/breaker box and then turn it back on. You should then have the oven door unlocked
Posted on Aug 08, 2009
Oven door on lock
is the light oven on??? can you see the switch/button that the door would hit against to turn light off?? if so depress button so the lifht goes off, and start a clean cycle.This should make the lock mechanism engage fully. then cancel cycle and should fully disengage lock/latch (you need to depress light switch to trick unit into thinkin the door is closed)
Mar 08, 2008 | Kenmore 30169 Electric Single Oven
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Door locks and F9 fault codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven door lock engaged while NOT in cleaning mode with door open. Will not disengage. Cycled main power, cancel button does not work; Oven also inoperable. HELP! Appreciate any tips or tricks to get it...
your oven uses a motor lock latch #316028101 around 100 dollars the motor or the linkages to the motor are most likely bad . the control board could be supplying the voltage to the motor is which case the board would be bad if the are no sensors telling it to lock the door If you are not pretty handy with a schematic and a meter I would suggest you call someone. F3 can be a thermal fuse or maybe the wrong resistance on the over sensor
Dec 14, 2008 | Kitchen Ranges
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
Frigidaire FEF336BC Electric Kitchen Range Logo
15,918 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
